Old 08-04-05, 12:53 PM   #1
thor
Default Differences between SVs from different years
Hiya,
I'm looking at getting a pointy half faired SV. These are the ones from 2003 onwards? Are there any differences between the 03, 04 and 05 models apart from age?
Thanks!
Old 08-04-05, 12:57 PM   #2
Biker Biggles
Biker Biggles's Avatar
They are all as ugly as each other,unlike the curvy ones which are much nicer
Old 08-04-05, 01:01 PM   #3
Steve H
Old 08-04-05, 01:01 PM   #4
Viney
Default Re: Differences between SVs from different years
Originally Posted by thor
Hiya,
Thanks!
Hey Thor
the 05(K5) has black frame
the 04(K4) had a slighly different exhuast link pipe ans lower foot pegs if i remember
There may be other differences that i dont know about, but basicaly they are the same bike underneath.
Old 08-04-05, 01:03 PM   #5
Steve H
Cue rants about not being constructive!
Seriously though, I dont think that there are a lot of differences apart of course from various colours and the '05 bikes having a black frame.
Old 08-04-05, 01:03 PM   #6
Sudoxe
K4 has a higher subframe, and a toolbox under the battery box. It's available in the best colour (Yellow)
Few bits here and there, nothing too major though
Dan
Old 08-04-05, 01:06 PM   #7
Flamin_Squirrel
Yes, but very subtle.
03 has fuse box under the riders seat. 04 (and I think 05) have a slightly lower seat/subframe, so theres no room for the fuse box, so it's mounted under the pilion seat instead.
Since the fuse box is under the pilion seat, the toolkit got moved for the 04 bike, into a box behind the rear shock.
Old 08-04-05, 01:10 PM   #8
thor
Thanks all.
I'm not so interested in the black frame, so that's out. 03 or 04 it is then (providing I can secure a test ride).
Old 08-04-05, 01:21 PM   #9
BillyC
BillyC's Avatar
I think you'll find that the K4's subframe is lower, and by quite a lot. That's why you can't get the toolkit in there, and they had to move the fuses.
As I understand it:
K2
Last of the curvy SV's, finally introduced preload caps on the front forks.
K3
First of the pointy models - and quite different to the curvy. Introduced an oil cooler for the 650 engine, and fuel injection. Radiator fan now operates from it's own temperature switch located in the radiator.
K4
Adjustment on the K3 apparently through feedback from dealers and owners. Seat resculptured to be narrower, and lower. Footrests lower and further foward. Rear subframe lower, to cater for adjusted seat, and make it easier for pillions to mount. Consequently exhaust structure is angled slightly differently. Because of less space under the rear seat, toolkit has to be moved to a new separate compartment in the battery-box/undertray. Minor adjustments to the water pump and radiator. "Suzuki" logo on the tank was updated to just an "S".
K5
As per the K4, but with black frame. The radiator is changed to a narrower design - to avoid serious damage in a slide. Naked's now come with a gay wind deflector over the clocks above the headlight.
Old 08-04-05, 01:39 PM   #10
SpankyHam
Curvy once are best looking.
2000 Model (in yellow) is the fastest
That's all
Suzuki DRZ 400 - what are the differences? Tim in Belgium Bikes - Talk & Issues 9 16-03-09 07:20 PM
What are the differences between....... andyharding SV Talk, Tuning & Tweaking 8 22-11-07 07:23 PM
k1 , k2 , k3, k4 differences? florida650 SV Talk, Tuning & Tweaking 9 24-06-07 02:17 PM
Fork Differences Bikerz SV Talk, Tuning & Tweaking 4 25-01-07 10:30 PM
K2 and K3 Differences Skip SV Talk, Tuning & Tweaking 8 20-03-05 09:15 AM
