Old 11-04-05, 08:52 PM   #1
JakeRS
Default Brakes
Hi guys, as you probably know I got my SV the other day. The front brake feels weird though, when I pull the lever in it doesn't pull in smoothly unless i pull it really hard. It kinda crunches... I dont really know how to describe it... I changed the setting ont he lever from 5 to 1 and this made a slight difference... what else can I do?
JakeRS
Old 11-04-05, 09:02 PM   #2
jonacol
put a dab of grease on the end of the brake level where it pushes against the master cylinder piston.(near the pivot point of the brake lever.)
Old 12-04-05, 02:28 PM   #3
JakeRS
the master cylinder eh... i honestly have no idea what that is!
Old 12-04-05, 02:33 PM   #4
Flamin_Squirrel
Look at the left of the brake lever. It presses on a piston when you squeeze the brake. Thats the master cylinder. Grease the bit where the metal lever presses on the rubber cover.
Hope that makes sense
Old 12-04-05, 02:34 PM   #5
Viney
Definitly dont start touching anything to do with brakes.
Jake, if you can live with it until you come to one of the meets, then we'll take a look at it for you.
Old 12-04-05, 10:42 PM   #6
JakeRS
yeah i can live with it, just keep accidently locking the back wheel up using too much rear...
not sure when i'm gonna be able to get up to a meet... my work hours are VERY flexible...
Old 13-04-05, 02:22 AM   #7
Graham
The lever pivot needs a lube, Get some silicone spray and give it heaps. You will be as surprised as I was.
Old 13-04-05, 12:15 PM   #8
JakeRS
again... which bits the lever pivot
im guessing the pivot on the lever but u never know
brakes / oil lapchick = mad hungarian Ancillaries 4 03-03-07 03:03 PM
brakes oldsvrider SV Talk, Tuning & Tweaking 4 01-01-07 03:24 PM
Brakes Hogzi Stuff Wanted 0 06-03-06 08:47 PM
Brakes ! stewboy SV Talk, Tuning & Tweaking 3 19-12-05 04:55 PM
Brakes - Help! Yokel SV Talk, Tuning & Tweaking 7 11-04-05 08:17 PM
