View Poll Results: How long did it take you???
30 mins 1 5.56%
1 hour 4 22.22%
2 hours - 4 hours 6 33.33%
Never fitted one 6 33.33%
5+ hours because I'm useless 1 5.56%
Voters: 18. You may not vote on this poll
Old 27-04-05, 08:11 PM   #1
riktherider
Default Time spent fitting an under tray
hey, just a bit of a wondering really. ive ben scanning through a few places, and people seem to be taking ages to fit there aftermarket undertrays. i brought a powerbronze one today, and expected it to take me a good couple of hours to sort out, but loe and behold it only took me about 50 mins!!
one person said it took him 6 hours to do!!!!
just want to see how long it took other popel to fit.
Old 27-04-05, 08:36 PM   #2
Stig
Where is the option for never fitted one
Old 27-04-05, 08:37 PM   #3
Stig
Oh, there it is
Old 27-04-05, 08:45 PM   #4
riktherider
eh, how did you do that boi!!! if ou do that add another for 5+, some other geezer took about 6 hours to fit his
Old 27-04-05, 08:52 PM   #5
Stig
Tis done
Old 27-04-05, 08:55 PM   #6
riktherider
ta
Old 27-04-05, 09:00 PM   #7
BURNER
About 45 minutes. So I clicked an hour, shouldn't take longer than that.
Old 28-04-05, 01:38 PM   #8
Cloggsy
I've got a powerbronze one... It fits over the top of the original (on a K3 it does anyway,) but you need to 'modify' the original undertray slightly for it to fit...
The only part that is a bit of a tw@ is fitting the plastic nuts & bolts (which are used instead of the pop-fittings underneath ) The easiest way I've found is to use a 10mm socket on a screwdriver fitting (if you've got one) & using a small strip of paper, wedge the 10mm plastic bolt into the socket. Feed the plastic screw/bolt from the bottom, up into the under-seat compartment & screw the nut on (whilst holding the bolt in place with a screwdriver) - its also much easier to undo & remove all the screws, pop-fittings, nuts etc. which hold the seat plastics in place first, this will allow you lots of space/manuverability to get the plastic nuts/bolts for the undertray in place...
I've fitted it & removed it many times now... I have the scraped knuckles to proove it
Old 28-04-05, 01:53 PM   #9
riktherider
i only ended up using two nuts and bolts to hold the under tray on, the rest of it is sloted under teh side panels. pertty solid though which is good.
Old 28-04-05, 02:09 PM   #10
Iansv
Dealer fitted mine, charged me an hour
Fitting a clutch for the first time. (In Process, Curvy 99) vardypeeps SV Talk, Tuning & Tweaking 4 16-03-09 03:30 PM
under tray bod Stuff Wanted 0 02-01-08 08:32 AM
under tray chrisderby Stuff Wanted 2 18-04-07 08:06 PM
Under tray cuffy SV Ecosse 9 01-06-06 12:09 PM
Fitting Scottoiler and Hamicad tail tidy at the same time? Kylie SV Talk, Tuning & Tweaking 4 12-09-05 10:15 AM
