Old 07-05-05, 01:45 PM   #1
swear
Default Problem with my SV650
I was out driving and came across a empty parking lot, so I decided to try and do some "moving burnouts" (you know when the bike moves forward and burns rubber at the same time), anyhow, so after a few failed tries because of the front brake not really working properly the bike stops moving all together, I mean it's on and running, I can change gears, the clutch basicly works (doesn't feel diffrent or anything), it just doesn't move forward, well actually it does move a little bit forward on first gear, but not much.
I played with the clutch and throttle, then suddenly it just didn't move forward, I didn't hear any odd sound or anything...
What could be the problem?
Old 07-05-05, 01:50 PM   #2
Itching 2 go
have you hit the kill switch?
but seriously, you may have completely burnt your clutch out. you engage a gear then let the clutch out and the engine meets some resistance but goes no where.
Old 07-05-05, 01:50 PM   #3
TSM
The Sick Man
TSM's Avatar
burnt out clutch????
Old 07-05-05, 01:51 PM   #4
Itching 2 go
oooo fastes finger first
Old 07-05-05, 02:04 PM   #5
sprocket
ohhh unlucky dood
Old 07-05-05, 02:39 PM   #6
swear
Originally Posted by sprocket
ohhh unlucky dood
Yep, "Bad Luck" is my middle name
Old 07-05-05, 05:27 PM   #7
Ash999
i dd practically the same thing on a cb250, not burn outs but pulling away from the lights from holding the front brake lever in and a bita throttle, had exactly the same symptoms and would go into gears, but didnt move, engine still ran smooth, it turned out apparently to be a damaged gear selector fork,wtf? thats what the mechanic said, dont know what it is or if the sv has one but may help, but I would be tempted to say yep a burnt out clutch, specially on the sv with burn outs,
Old 07-05-05, 05:58 PM   #8
hall13uk
so its not only me then bad luck dude
i say 99% that you have burnt out clutch i did it on my bike doing burnouts cost me £500.00 at my local dealership!!!!!
Old 07-05-05, 07:19 PM   #9
£500 On a SV?
Old 07-05-05, 07:21 PM   #10
Carsick
Originally Posted by northwind
£500 On a SV?
That's what we said.
SV650 99 Curvy (Major Problem?) vardypeeps SV Talk, Tuning & Tweaking 14 09-03-09 02:14 PM
Buying a sv650 with a slight problem HighRisk SV Talk, Tuning & Tweaking 8 27-02-09 03:57 PM
problem with k5 sv650 PLEASE HELP hooters SV Talk, Tuning & Tweaking 3 22-11-08 10:45 AM
SV650 speedo in km, problem? Feldspar SV Talk, Tuning & Tweaking 8 17-08-08 10:14 AM
SV650 won't start - possible battery problem? B SV Talk, Tuning & Tweaking 6 08-08-06 07:20 AM
