Old 11-05-05, 11:09 AM   #1
Ransom
Default Restoring pitted forks
Is there any way of restoring pitted forks or is it Mission impossible. I was thinking of giving them a going over with a fine wet/dry and then give em a good pasting of laquer?
Old 11-05-05, 11:28 AM   #2
jonboy
They can be restored quite easily, it just takes humungous amounts of elbow grease. Depending upon how good a job you want to do, you only need to remove the front wheel and you can then access all of the fork lowers.
Wet & dry plus Autosol (or similar) for several hours, otherwise you'll have to remove them and take them to a metal polisher.
After that you have the choice of either leaving them unlaquered (which will require weekly cleaning to keep them looking good) or preferably have them professionally relaquered (i.e. don't send thewm to Suzuki) or powdercoated (a clear option is available).
Viney's got some nice pics of his ones that he did himself.
Old 11-05-05, 11:34 AM   #3
MavUK
How easy is it to get the wheel on / off?
I've nothing against the polishing, and spraying is no issue - but I've never really looking into dismantling the bike before...
Stu
Old 11-05-05, 11:45 AM   #4
Mike1234
Originally Posted by jonboy
They can be restored quite easily, it just takes humungous amounts of elbow grease. Depending upon how good a job you want to do, you only need to remove the front wheel and you can then access all of the fork stanchion.
You are aware that the stanchion is the shiny chrome bit and not the lowers that the wheel and axle fit to?
Old 11-05-05, 11:51 AM   #5
jonboy
Yes Mike, it was today's little test. You did well.
Old 11-05-05, 11:51 AM   #6
Ransom
Oh cool, so it is possible, i was just going out on a whim.
Next step, where can i get some elbow grease...
Just kiding!!!
Old 11-05-05, 11:52 AM   #7
Mike1234
Awesome, what did I win?!
Old 11-05-05, 12:32 PM   #8
Quiff Wichard's Avatar
you won a tube of autosol cos Jonboy now using Mr Sheeny shiny silver polish thingy and he has a garage of autosol to lay off.!!!
Old 11-05-05, 12:45 PM   #9
jonboy
This is true. Mike is welcome to collect a half-used tube of Autosol at his convenience.
Old 11-05-05, 01:04 PM   #10
Mike1234
Most grateful but you are making the assumption that my bikes last long enough to actually need cleaning! I normally just bury them int he gravel at the end of the start finish straight and walk away, well, get stretchered away...
front forks pitted and look bad help ! Quiff Wichard SV Talk, Tuning & Tweaking 29 28-04-10 10:18 PM
Restoring/modding an old mini andyb Idle Banter 25 27-12-07 09:24 PM
Pitted Forks andy SV Talk, Tuning & Tweaking 1 29-05-07 08:08 PM
Restoring my exhaust, chrome / anodise? jon Bikes - Talk & Issues 9 02-12-05 12:39 PM
Restoring my 2000 curvy jpb Bodywork 0 22-11-05 08:19 PM
