Old 12-05-05, 11:00 AM   #1
suzsv650
Default Indicators
shal i buy LED ones or normal ones!
ive hard about al the problems with LED ones so im a bit
thank you please
Old 12-05-05, 11:05 AM   #2
Flamin_Squirrel
You have to mess about with fuses for the LED indicators. It's not really a problem, especialy if you prefer the look though. If you're not fussed, get normal bulbed 'cators.
Old 12-05-05, 11:19 AM   #3
Nouf
I fitted the led rear tail lights with built in indicators to my K4 last night. It was a straight fit. Havent heard of any problems with leds personally.
Old 12-05-05, 12:13 PM   #4
Bikerz
my rear indicators are LED triangles in carbon fibre and were a direct swap!
Old 12-05-05, 01:03 PM   #5
Keitht
Most LED indicators will need a resistor fitted in parallel with them to get them to flash at the same rate as a bulb - not fitting one will cause them to flash very fast. Also, a normal LED on it's own will normally need an extra resistor in series with it to ensure that the voltage is brought down to the correct one for the LED (most LEDs cannot handle 12v). A lot of LED indicators will have this oe built in, and some will come with the parallel resistor as well - depends which one you get.
Even without the kits they are very easy to fit with minimal electronics knowledge.
Old 12-05-05, 04:21 PM   #6
Warren
i got some led indicators and fitted them this week,
gotta be honest, i thought led's would be brighter than standard indicators, there not as visible during the day, but brighter in the evening.
Old 12-05-05, 07:23 PM   #7
TSM
The Sick Man
TSM's Avatar
do indicators need to be orange to pass MOT???
I saw a mod that someone did and fitted the indicators in the rear footrests with LEDS. Was thinking of doing that.,
Old 12-05-05, 08:50 PM   #8
Warren
i dont think so, as you can get clear LED ones that are E-marked.
i could be wrong tho.
Old 13-05-05, 10:21 AM   #9
Nouf
My rear cators are clear lense and havent had any problems as yet. Ok I only had them on for 2 days but still
Old 13-05-05, 10:34 AM   #10
TSM
The Sick Man
TSM's Avatar
what i ment was , does the light have to emit orange when blinking.
Remove front indicators space -Move indicators in headlights JanGoris SV Talk, Tuning & Tweaking 5 19-04-06 09:27 PM
Which indicators? aimhamilton Bikes - Talk & Issues 7 01-04-06 04:57 PM
Indicators mike_b Stuff Wanted 2 13-01-06 02:03 PM
Indicators enabb For Sale - SV's and SV related items 2 11-12-05 10:42 PM
gsxr 600 indicators and sv k5 indicators (put down - drop) swamp SV Talk, Tuning & Tweaking 3 03-04-05 02:25 PM
