Old 26-05-05, 07:42 PM   #1
Quiff Wichard's Avatar
Default re jetting
ok- further to some comments on here in answer to some of my questions
how mush does re jetting cost? and how long will it take to be done ?
ta
Old 26-05-05, 10:18 PM   #2
BURNER
Do It Yerself for pennies, or upwards of £125- incl dynojet kit.
You got a full system or an end can?
What air filter you running?
Old 26-05-05, 10:41 PM   #3
just end can and standard filter
Old 26-05-05, 10:41 PM   #4
i int got a clue how to re jet meself!!( the bike ! but me doin it meself i mean !_)
Old 26-05-05, 11:14 PM   #5
Google for "Catpoopman", vey helpful site there. Rejetting sounds scary but it's really not that bad- though you might find the screws on the carbs to be bad tempered.
Where do you find it not running well? Idle, midrange, high midrange, wide open throttle? Because if it's not bad- particularily if it's only problematic up top which I'd suspect- then you could fix it yourself pretty easily. It's only when you get into mucking about with the needles, mix screws etc that it gets a bit fiddly.
Old 27-05-05, 02:06 PM   #6
sexysi
Do you really need to rejet them!!!
I run a standard filter with a reni end can, and there is no need to rejet at all. However I fitted a BMC filter with the end can and the bike did need rejetting, it was just being starved of petrol, with a loss of power. So I have fitted 142 jets, this took half an hour to do, it is a piece of **** if you take your time. The one thing to watch out for is the front choke needle connection, almost forgot this and ripped the thing out.
It also allows you to regrease all of the carb linkedges for the comming winter. Something now of us probably do that often.
I might do a photo How to guide soon for Curvey Sv's
sexysi
Re-Jetting SV650S catchsomesv650 SV Talk, Tuning & Tweaking 14 29-04-18 10:36 AM
jetting trialspaul Mini-Twins 1 18-02-09 07:38 PM
Help with re-jetting Spoon SV Talk, Tuning & Tweaking 14 08-08-08 04:00 PM
blueflame can - jetting? 01 sv650s SV Talk, Tuning & Tweaking 7 26-09-06 12:59 PM
K&N panel jetting 01 sv650s SV Talk, Tuning & Tweaking 5 17-09-06 09:26 PM
