Old 06-06-05, 05:08 PM   #1
snoopy
Default This exhaust on the SV?...
100mm diameter, 18inch length, 54~mm inlet (same as SV). I would have to weld a pipe at angle of SV exhaust and get a baffle. Still could be cheap. Thoughts?
Old 06-06-05, 07:48 PM   #2
What happened to the R1 pipe?
Old 06-06-05, 08:10 PM   #3
Viney
It will be very loud that size and the carbon will split inside 3 months, other than that, go for it
Old 06-06-05, 08:23 PM   #4
snoopy
I couldn't get it welded on -alu and steel is a nasty combo without a MIG.
Why will the carbon split within 3 months? Also I intend to get a baffle.
Old 06-06-05, 11:21 PM   #5
Dan_SV
I have a Standard Can I cut off a system I purchased from Ebay. It's dented and a little scuffed, but would get you through an MOT. You would need a sleeve to connect it to your downpipes, but these are readily available from ART etc.
If your interested PM me.
Dan.
what exhaust is this? hovis Bikes - Talk & Issues 32 25-01-09 07:19 PM
gasoline in my exhaust... fuel in my exhaust mtb83201 SV Talk, Tuning & Tweaking 5 29-04-08 10:58 PM
Exhaust 4 exhaust swap? SVnutta!! SV Talk, Tuning & Tweaking 2 29-06-06 04:26 PM
Which exhaust is best.?? BigLee Exhausts 31 09-07-05 09:26 PM
