Hey
Got a new BOLT-on IXIL racing on my SVS650-K2 this evening, that didnt work out. My bike runs up/down up/dowm in rpm all the time, until i reach 6000rpm It pulls back the bike as well -NOT NICE. Seems like too little gas, too much air ?? Runs with Dyno2, 165 mains, BMC race !!! Any ideas for help, and to solve it ? Cheers Per |
Hmmm, the can shouldnt cause that on its own. Did you do the jetting, filter etc at the same time? Its probably the filter. I know that theres a race and a race rs, one works, one dont. Mike1234 will be ya man.
Nope, did the Dyno and the fiter this winter, pre BOS slip on.....
That worked fine. Mounted the bolt-on a few hour ago, and it can only be that one. |
#4 | |
Tried the stock filter, didnt help....
BUGGER !! |
6000 is your main jet kicking in...
165 with a BMC Race? Sounds like running rich. 165 with a BMC Race RS is about right. Try taking the filter out and reving to see if its got same effect. You can tell if its running rich that way. Whatever you're using, with a 165 mains you need tank spacers to supply the air. Northwind will be along shortly to explain... |
So what do i change it TO ?
Got tank spacers allready Think i got at BMC Race RS (thats the one with the biggest hole) yeah ? |
what mains are you using? mikuni? dynojet?
#9 |
Dyno 2....
three bolt exhaust flange | svrich | Stuff Wanted | 4 | 09-02-09 11:03 PM |
Exhaust bolt broken off in Head | Aidan | SV Talk, Tuning & Tweaking | 8 | 24-09-08 11:08 AM |
exhaust header bolt size ? | Sideshow#36 | SV Talk, Tuning & Tweaking | 3 | 04-08-07 11:31 PM |
I just got my new SV650 and want slip on/bolt on Exhaust | Madtrotter1 | Stuff Wanted | 1 | 24-07-06 07:51 AM |
Exhaust bolt corrosion | mynameis | SV Talk, Tuning & Tweaking | 2 | 06-12-04 11:03 PM |
