Old 19-06-05, 06:55 PM   #1
will
Default sore a*se despite gel seat
just come back in from a 2 hr run, and my a*se is aching soooooooooooooo much, worse with the gel seat than when i had the standard seat.
i have also had the suspension changed to stiffer fork springs and a gsxr 1000 shock.
why am i getting such a sore backside? could it be that the suspension set up is too hard or is the gel seat less comfortable for some owners a*ses?
any ideas?
W
Old 19-06-05, 07:13 PM   #2
bendelfont
Default Gel seat
I found my **** was a bit sorer with the gel seat than the standard - it's certainly firmer - the only time it isn't is when i' m wearing my thermal long john things (completely impractical on a day like this!) - i read that someone uses cycling shorts under their trousers (with the pad in the **** cheeks) - that might do it? I'm going to try the standard seat again to see which i prefer - i'm not entirely convinced by the gel seat
Old 19-06-05, 07:19 PM   #3
jonboy
You could well find that the spring on the gixxer shock is way too hard for the SV.
You could also be a wuss .
Old 19-06-05, 07:22 PM   #4
suzsv650
try moveing about on the seat like leaning off the seat round corners
try standing up on the pegs
or a panzey!
Old 19-06-05, 07:23 PM   #5
suzsv650
mised out "your "
or your a panzey
ops
WOW thires a edit button! never knew that
Old 19-06-05, 07:25 PM   #6
jonboy
(You can use the Edit button )
Old 20-06-05, 07:01 AM   #7
Eat more pies.
Result - automatic built in Jelly Seat, never get a sore bum again.
Old 20-06-05, 07:24 AM   #8
mysteryjimbo
Or dont do 2 hours runs...... Two one hours runs are better with a break.
I did two trips of two hours this weekend without the rear end pain thanks to a 10-15 minute break.
Old 20-06-05, 07:28 AM   #9
No no no, get fatter, it really works I tell you.
Nine hours on the bike yesterday, no sore ****, bit sweaty though.
I bet you really wanted to hear that .
Old 20-06-05, 07:29 AM   #10
Viney
See its all a myth, one that you have had to try. I found that the gel seat made my back ache as well.
sore leg fergie Bikes - Talk & Issues 11 13-05-08 08:37 PM
Sore leg darylB Idle Banter 3 29-06-06 01:39 PM
Sore wrists Diveboy Bikes - Talk & Issues 18 19-08-05 03:41 AM
sore bum :0 Ablazze SV Talk, Tuning & Tweaking 8 04-06-05 11:24 PM
sore bum alison_w SV Talk, Tuning & Tweaking 18 09-12-04 08:32 PM
