Old 21-06-05, 11:43 AM   #1
Mr Steve
Default Will a High level exhaust off a K3 fit a K5?
i have got a new K5 but was looking at buying a second hand high level exhaust that is on a K3... does anyone know if swapping it onto mine will work?
Old 21-06-05, 11:46 AM   #2
Carsick
It shouldn't work, no.
The K4-5 have a slightly different rear subframe to the K3 so the bracket won't line up properly. The link pipe needs to be a bit different.
You might find that as a high level you can relatively easily make up a new bracket, but I haven't looked into that.
On the other hand, it may be possible to get hold of a K5 link pipe from somewhere and use that.
Only take that last option if you get a really good deal on the can, because the pipes are not cheap.
Old 21-06-05, 12:30 PM   #3
BillyC
BillyC's Avatar
No
Old 21-06-05, 12:34 PM   #4
Mr Steve
cheers!
new one it is then....! bugger, more money.
Old 21-06-05, 01:47 PM   #5
minky
if I recall correctly, do cheap exhausts and may do link pipes. The other option is getting a link pipe from someone like Gazelle Stainless and buying any can.
Renegade - High level exhaust Biker Biker For Sale - SV's and SV related items 27 20-10-08 07:47 PM
High level exhaust - Help required! UKStreetFighter SV Talk, Tuning & Tweaking 28 15-03-07 10:06 PM
High Level Exhaust - Any recommendations? BLK SV SV Talk, Tuning & Tweaking 7 07-10-06 11:38 AM
Exhaust, High level or not to high level..? Horney SV Talk, Tuning & Tweaking 5 06-10-06 03:54 PM
Convert exhaust to high level TSM SV Talk, Tuning & Tweaking 3 22-02-05 01:58 AM
