Who’s has bought a high level link pipe from banditmania?
http://www.banditmania.co.uk/ExhaustWork.htm BMSHPSV SV650 ALL YEARS SINGLE HIGH LEVEL PIPE WORK. COMES WITH HEEL PLATES, BRACKETS AND CLAMPS. EVERYTHING YOU NEED TO FIT STRAIGHT ON. YOUR SYSTEM DOES REQUIRE CUTTING TO FIT THE HIGH LEVEL. MADE FOR 2" O/D SLIP ON CANS ive still got to measure up my Viper to make sure it will fit correctly but im worried that it will burn my boots too! ![]() oh and also i made the cut for the viper about 1 1/2-2" from the weld would this be far enough back to fit the high level ?? i will ring them up at a later data to make sure this is all correct but im wondering about the pipe in general. Any information guys? thanks for any info |
not sure about the measurements...
![]() Let me know how you get on! Good Luck ![]() |
you dont hapen to know the size of the end do you ?
i realy cant be botherd to faf around with the stupidly stiff pipe lol! |
Not exactly, but the clamp on my exhaust says 48-52mm, so say 50mm average which works out as virtually spot on 2". Again I'm guessing but sounds pretty close. Can't be bothered to take mine to bits either!
![]() In regards to joining the link pipe I can't see that it should be a problem! Hope this helps.... A bit ![]() |
#5 | |
ahhh ta and
i gota get R&Gs first tho lol |
Link Pipe | -Ralph- | Stuff Wanted | 2 | 14-02-09 03:28 PM |
Refitting standard pipe: link pipe? | Jay1 | SV Talk, Tuning & Tweaking | 6 | 17-04-08 09:51 AM |
link pipe gap | John 675 | SV Talk, Tuning & Tweaking | 12 | 19-02-08 10:23 PM |
Link Pipe | Ian1971 | Stuff Wanted | 1 | 10-09-07 12:10 PM |
Link Pipe | Steve226 | Stuff Wanted | 4 | 14-12-06 09:50 AM |
