Easy to fit? (Im a mechanical dunce!
![]() ![]() Any info would be greatly appreciated. Cheers guys and dolls. |
Theres a company on the offers page that does em cheap, otherwise busters where I got mine from
Dealer fitted mine so don't know how easy/hard |
it's quite easy to **** it up and get air in the system, get a dealer or a competent mate to do it.
um i dissagree, pecice of **** to fit, wont take more than an hour to do all 3! bsicale butifly bolt on each end (um i call them buterflies., they normal bolt with hold thorugh (so fluid goes through))
Bleeding system just a case of making sure resiviour full of fluid(use new dot 4 if i were u) and pulling lever on standing on it, opening and closing bleed value let go and repeat till its all hard and u can lock it up ![]() |
#5 | |
#6 | |
Get a brake bleeder. Essentially a bit or tube with a one way valve in. It fits over the bleed nipple at the caliper.
Fill the calipers and the master cylinder with brake fluid , then fit the hoses with the banjo bolts. Pull the brake lever slowly, don't go pumping it like a teenager with a copy of penthouse. Remember to keep the master cylinder topped up. Lock off all of the bleed nipples, replace the master cylinder lid and tie the lever to the handle bars over night. |
#8 | |
![]() You've got to be joking. Right? ![]() A. |
#9 |
Just fitted HEL to mine. Not a difficult job but points to note are-
Make sure the lines are routed so that they do not get trapped or chafed during normal suspension and bar movement and do not interfere with the range of movement of same. Replacement lines are less flexable than origonals. Dont get any muck in the brake fluid. Wipe off any spilt fluid immediatly, it eats paint! Easybleed NRV makes bleeding a lot easyer, a bit of PTFE tape around the bleed nipple stops air getting in here. Check and recheck everything when you've finished and get a make to do an independant check if you can, an emergency stop is not the best time to find you screwed up! ![]() |
#10 |
I really hate bleeding brakes... I'm not bad at this DIYing lark but I'm still no good at bleeding brakes, it's slow and frustrating and doesn;t work for ages for no apparent reason then suddenly works even if you're not doign anything different.
Mityvac seems to be the way to go for an easy life, I'm still mucking about with a Gunnsons Eezibleed pressure bleeder but you need a spare reservoir cover and seal to make it usable. Otherwise it basically functions as a brake fluid sprayer ![]()
braided lines | xbox650 | SV Talk, Tuning & Tweaking | 23 | 02-12-08 04:45 PM |
Braided lines | yorkie_chris | SV Talk, Tuning & Tweaking | 1 | 31-05-07 09:58 PM |
HEL Braided lines | Couerdelion | SV Talk, Tuning & Tweaking | 7 | 30-05-05 07:13 AM |
HEL Braided lines | mysteryjimbo | SV Talk, Tuning & Tweaking | 8 | 10-02-05 10:20 PM |
Braided Lines | 454697819 | SV Talk, Tuning & Tweaking | 14 | 08-01-05 03:37 PM |
