Old 24-06-05, 04:17 PM   #1
goof
Default Look in if you've changed your fork oil seals!
Please see last post - almost there!
Old 24-06-05, 08:56 PM   #2
I can't remember if you have to release the damper rod or not... But basically you pull the two ends apart, and it works like a slide hammer. Pop!
Old 24-06-05, 08:57 PM   #3
PS if you're having trouble I've got a set of forks you can borrow till yours are sorted, if you can get them from Edinburgh...
Old 24-06-05, 09:10 PM   #4
21QUEST
21QUEST's Avatar
Yep have to remove damper rod bolt(underneath) fork leg.
Ben
Nemo me impune lacessit.
Old 24-06-05, 10:41 PM   #5
goof
Heh, thanks North, you're a generous guy, you keep trying to give me stuff but that's ok, sure I'll get these sorted
Thanks as well Ben - I don't think I've undone the damper bolt because when I checked the underside of the fork there was no bolt visable. There a tube running across the bottom of the fork - I take it this is removable and I'll get access to the bolt after taking the tube away? (I just ask because the tubing didn't look removable, looked like it was molded with the fork).
Old 24-06-05, 11:20 PM   #6
Godikus
oi northy. i seem to have misplaced my SV. don't spose you have a spare one kickin' around i could have?
ps i can collect
worth a try
Old 25-06-05, 07:15 AM   #7
21QUEST
21QUEST's Avatar
The tube(spacer) is removeable. Just tap it out. Clean and lightly grease it before you put it back.
Am I right in assumming that you are not the Haynes manual. If that is the case , it'll be good to invest in one.
Ben
Old 25-06-05, 07:38 AM   #8
On disassembling forks I said: this.
Old 25-06-05, 10:15 AM   #9
goof
Thanks Ben, one step closer
No, it wasn't the haynes it was the PDF one on the site here, which is a bit muff
And cheers Sid - I found that through the search but in your description you say "the bolt at the bottom of the forks" but no mention of the spacer. Is the spacer what you were referring to when you said 'shove a broom handle in there'?
Old 26-06-05, 04:31 PM   #10
goof
Managed to finally get the bottom fork bolt out...nightmare!
So, have got the new fork seals on but I'm wondering how to get them securely into the stanchion without a "special tool" - the washer and seal sit higher than the old ones did before I removed them (they were about 1cm down the tube, leaving space for the dust seal to go on top so I must have to knock them down somehow). Any tips on how to do this (tempted to knock the oil seal down with a screw driver but don't want to knacker it).
TIA
Fork Seals chris8886 SV Talk, Tuning & Tweaking 2 04-02-08 09:04 PM
Fork Seals. Grinch SV Talk, Tuning & Tweaking 7 24-05-07 11:45 AM
Fork seals have gone JakeRS SV Talk, Tuning & Tweaking 3 23-07-06 12:29 PM
fork seals ruff_ryder SV Talk, Tuning & Tweaking 11 29-06-05 05:43 PM
Fork Seals and Oil R11ysf SV Talk, Tuning & Tweaking 1 11-03-05 10:46 AM
