Old 07-07-05, 06:20 PM   #1
Default Misbehaving clutch...
So, my clutch has added a new trick to its usual tricks... I've played with the adjusters at both ends but to be honest I'm not totally sure what i'm doing with the locknut/screw preload thing, so I could use a bit of advice...
Basically, it's slipping at wide-open throttle whenever I'm anywhere near peak power... But lever play is pretty much spot on. On the other hand, it also won't select neutral 9/10 while the engine is running- so I've got a slipping issue, and a not-disengaging issue, both at the same time
Old 07-07-05, 06:37 PM   #2
First off make sure it's adjusted right, like this:
Slacken off cable adjusters at top and bottom, loosen lifter locknut, back out screw a bit, ensure that lifter arm is as far down as it will go, gently turn screw in until it contacts pushrod back out a bit, (~1/8th of a turn), then nip up the locknut, roughly adjust cable with lower adjuster - not too tight - then with top adjuster ensure that there remains a little slack all the way from lock to lock.
If that fails to do anything useful, check that the lifter's working right and the ramps and balls aren't knackered, if not that then the cover's going to have to come off to examine the plates, clutch basket and hub, which could be warped or notched.
Old 07-07-05, 06:43 PM   #3
Yup, that's how I've got the lifter set up... I'll check the ramp and ball mechanism tomorrow- who knows, just redoing the setup from scratch might help.
Cheers mate. I know nothing about clutches!
Old 07-07-05, 07:42 PM   #4
M.C.
M.C.'s Avatar
when i had my k1 the clutch started slipping and i just needed to slacken the lever a bit so there was about 5mm of play solved my problem
M.C. is offline   Reply With Quote
Old 07-07-05, 10:53 PM   #5
Nah, play's spot on- but at the moment I either have no neutral and a slight drag, or I have the slip under high power- there's no setting where I can get a middle ground.
Old 08-07-05, 03:26 PM   #6
embee
embee's Avatar
JASO-MA oil or car stuff?
Old 11-07-05, 02:01 PM   #7
10W-40 Castrol GPS semi-synth for bikes. I am not Andrew Charnley But good suggestion, thanks.
Old 11-07-05, 05:53 PM   #8
04SV650S
You should try to leave a little bit of play with the cluthc too ... the owners manual will give you a range to go by in terms of cable slash ... I just don't like seing somepople that have no slack at all... it makes it so that when you release the clutch that the fisrt portion still keeps it in neautral and its not as smooth in terms of gear shifting transistions...
Old 11-07-05, 06:58 PM   #9
took it to bits to have a proper look... There's an obvious shortage of ball bearings in the bearing/ramp arrangement, and the whole thing's kind of wobbly. It's never been problematic till now but then I suppose it could easily have sustained wear or damage over time because of the shortage- most likely I made a disaster of rebuilding it back when I did the ignition advancer mod, but it's possible it's been like that since I got it.
I've got a better compromise now, no slip and it'll hit neutral while moving, just not stationary- that'll do me till I can pick up some replacement balls and rebuild it, see if that works. Seems possible it'll be too worn for that though, I'll see.
Another thing that I'm very aware of, though, is that despite it being a fairly new cable the adjustors are right on the limit of their range, which doesn't bode well for the clutch in general- am I right in thinking that this could be caused by heavily worn plates? Or is it mor likely a side effect of the lifter problem?
Cheers all, especially Sid Squid (again)
Old 11-07-05, 08:51 PM   #10
Northy
Cut your losses and just buy a new lifter thingy*, whilst the balls do wear the lifter screw is pretty soft material and takes more wear than the balls do, it's unlikely that new balls will do any great deal of good if the screw hasn't got smooth tracks, add to that the clevis pin and the hole in the lifter lever often wear a bit oval too.
Generally speaking clutch wear makes tightens the adjusters, (usually more than offset by wear in the lifter and associated bits), as the fitted thickness off the clutch reduces as the plates wear, most likely your slack cable is due to lost motion as a result of wear in the lifter.
* About £25ish, IIRC, pack it up well with some sticky grease when you fit it, it needs little provocation to start wearing.
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
hey new clutch advice Kyoto Clutch srxaus SV Talk, Tuning & Tweaking 3 14-08-07 04:25 PM
Clutch VR46 SV Talk, Tuning & Tweaking 6 02-06-06 06:17 PM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
