mines dead. GS500 one on e-bay. Anybody know if it will work on '99 SV650S?
It will work but IIRC the wires colours/connectors are different, (don't rely on that I can't remember exactly), but if you fit it as long as you keep the red and the black, (+ & - respectively), connected like for like, the other wires, (alternator phases), can be connected in any combination.
thanks for that sid - excellent and timely advice.
i just hope it is the rectifier that is the problem. guess i'll know once i've got it on.... thanks again |
The SV reg/rec is known for failing, but before you spend any money on bits you may not need, check the tests I described here, and here.
intersting stuff that sid. problem is that my bike won't run. battery says 13Vdc across it's terminals. 13Vdc between the + terminal and any fastener on the frame (I think that indicates good earthing?) - and yet, nothing happens at all - no lights on the dash - not even a faintly discernible click when I hit the starter. It starts instantly with a jump from the car, but as soon as i take the jump leads off the battery terminals it dies. can it be that the battery is knackered, even though i'm reading 13Vdc across it? incidentally - i have checked all those readings with a different multi-meter, so i've eliminated that from the enquiry. even if the battery is knackered - shouldn't the bike still run on the generator once it's jump started from a car? i found the connector on the red cable to the rectifier to be burnt, so i replace it (with individual crimped connections) - but to no avail. that is what made me suspect the rectifier - apart from my ignorance of all things electrical except that rectifiers are common culprits. got any suggestions?
I need a Rectifier / Regulator. | Marv | Stuff Wanted | 3 | 19-08-08 12:43 PM |
Regulator-rectifier | beaniebikerbabe | SV Talk, Tuning & Tweaking | 15 | 27-05-08 12:33 PM |
Rectifier/regulator | Gordon B | Stuff Wanted | 12 | 02-01-08 11:00 PM |
Regulator/Rectifier? | Biker Biggles | SV Talk, Tuning & Tweaking | 22 | 31-05-07 08:55 PM |
K2 regulator/rectifier, new in box | northwind | For Sale - SV's and SV related items | 0 | 22-02-07 09:14 PM |
