The Sick Man
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
Buy these instead, much better, easier to use and more accurate.
You can get a two column version if you're too tight for the full set which will be useable for just about anything* you'll ever own. You get what you pay for. *Unless you're planning to buy either a Z13, CBX1000, Benelli Sei, RC211V, Laverda V6 or Guzzi V8, (doubtless others too, but I can't think of any right now).
The Sick Man
Seen thoes before, might get them or i will just wait till i get back from holiday.
Seems like i might not get them done by Viney before my holiday because he is busy with some stuff this gone and next weekend. With the carbtune kit, does it come with T peices for connection or do you have to remove the vac tubes temporarly?
You are more than welcome to borrow mine mate, just cant do them for you.
#5 | |
Just a quick question and didn't mean to hijack the post. A quick question to those who own the the Morgan Carb Tuner. Does it work well and is it worth the money?
Thanks in advance. Cheers! |
The Sick Man
woooa, my carbs were out, major. One was reading 8 and the other over 15 inches.
#8 | |
What Carb Balancer | thedonal | Bikes - Talk & Issues | 13 | 21-08-08 05:54 PM |
Wheel balancer | flymo | Stuff Wanted | 6 | 25-02-08 09:34 AM |
cheap carb balancer wanted....... | Marksv | Stuff Wanted | 6 | 18-05-07 08:08 PM |
Carb balancer for twin SU HS4's | Caddy2000 | Idle Banter | 3 | 27-04-07 07:37 PM |
Is this Carb balancer any good ? | SpankyHam | Bikes - Talk & Issues | 3 | 03-08-06 11:29 AM |
