Old 26-07-05, 08:32 PM   #1
Stig
Default Melted brake line ooeerrr
I have just realized that my high level pipe work has melted into the rear brake line. I have now made the necessary adjustments to make sure that there is clear air between the two. Now concerned that I will have to replace it.
The outer hose is well and truely melted but the don't think the inner hose is damaged. Should I replace or will it be OK
Old 26-07-05, 08:44 PM   #2
daddy_sperm
probably only cosmetic, but better to replace.
I don't think heat could have damaged the line. I am assuming they are braids?
Old 26-07-05, 08:44 PM   #3
chazzyb
I thought the rear line has a plastic outer sheath down a chunk of its length - is it that wot's melted? If so, I think it's only there to stop chafing of the pipe.
Old 26-07-05, 08:55 PM   #4
Stig
Then you thought wrong, they are standard lines.
Yes but it has melted quite a way in. My worry is that it has melted the inner hose as well.
Old 26-07-05, 09:11 PM   #5
embee
embee's Avatar
...pretty certainly an MOT failure anyway
Old 26-07-05, 09:12 PM   #6
Scoobs
Safety critical item. Don't mess! Replace!
Old 26-07-05, 09:38 PM   #7
Peter Henry
Treat yerself Ape..go for a braided line if having to go to the trouble of replacement.
Old 26-07-05, 10:02 PM   #8
21QUEST
21QUEST's Avatar
I had the same happen with my twin renegades. Never got to the inner so left like that. Passed MOT with no probs.
If you need to change I might have a spare rear you can have.
Safety critical ? . Oh well I suppose it is if you use the back break but BigApe doesn't use his .
Ben
Nemo me impune lacessit.
Old 26-07-05, 10:06 PM   #9
jonboy
Default Re: Melted brake line ooeerrr
Trust me it's knackered. The same thing happened to me. When the high-level Remus was fitted it was touching the brake line (cheers Nick ) and although you could see it was slightly melted it seemed fine. Until I took Mrs jonboy on the back and used the rear brake in earnest and it went pop slooshing brake fluid all over the rear wheel/tyre.
Just change it .
Old 26-07-05, 10:19 PM   #10
TSM
The Sick Man
TSM's Avatar
Me got old one from K2 bike. You want it?
HEL (The brake line company) breakz187 Bikes - Talk & Issues 4 05-04-09 08:59 PM
Hel Brake Line Length Biker_Billy SV Talk, Tuning & Tweaking 7 27-03-08 10:33 PM
Which HEL brake line set? thedonal SV Talk, Tuning & Tweaking 23 09-01-08 10:03 AM
Brake Line length Torn-Thorax SV Talk, Tuning & Tweaking 2 10-03-07 02:26 PM
Brake line bracket - anyone got one or where to get one? rich_r Bikes - Talk & Issues 5 01-11-06 09:11 AM
