Old 01-08-05, 07:55 AM   #1
Jdubya
Default Lubing the rest of the bike
Which is the best oil/grease to use after washing the bike. Specifically for lubing the moving bits and bobs around the gear lever, rear brake lever etc.
Someone suggested 3 in 1 lithium grease but I'd just like to find out what other people use and where else to grease I do the FS365 thing after washing anyway but obviously this is mainly anti-corrosion treatment...
Old 01-08-05, 05:04 PM   #2
embee
embee's Avatar
The usual stuff is "white grease", which you can get in aerosols.
That's what the dealers cover everything in if you have it serviced . It's water-resistant, ideal for footrests, sidestand etc.
Gear lever pivot will want something a bit thinner to work its way into the bushing. Thin oil, or a mix of engine oil washed in with WD40, seems to work well there.
Old 01-08-05, 05:13 PM   #3
Warren
is that bog standard multi purpose grease ?
or are the 2 competely different ?
Old 01-08-05, 05:39 PM   #4
chazzyb
I may be wrong, but I think white grease is white only so you can see where it's been splurged on.
Old 01-08-05, 06:14 PM   #5
ophic
ophic's Avatar
for the gear lever, my dealer explicitly recommended against WD40. Engine oil, he reckoned, was best for it. I concur as I always used WD40 on it and it'd last for a bit then get very stiff.
Silver SV650SK3, Fuel exhaust
Old 01-08-05, 08:46 PM   #6
KATIE_SV
Apart from XvS's Local Suzuki dealer (In WestLondon )
Old 02-08-05, 08:23 AM   #7
Last Action Pimp
dam right katie
Old 02-08-05, 09:38 AM   #8
Jdubya
I think the white grease in the spray can works quite well for the "hard to reach" areas. But I find that re-application is only needed after every two washes or so...
Is that enough? Should I be lubing more regularly?
lubing cables steveg SV Talk, Tuning & Tweaking 2 03-09-08 08:06 PM
My bike needs a rest... for some reason... keltoi Bikes - Talk & Issues 7 15-03-07 06:32 AM
Valve Clearance and Cable Lubing slippery SV Talk, Tuning & Tweaking 18 21-02-06 07:41 PM
Chain Lubing. yellowspanner SV Talk, Tuning & Tweaking 5 15-11-04 05:57 PM
a lubing good question. Warren Bikes - Talk & Issues 3 20-10-04 06:55 PM
