Can anyone recommend some LED indicators? Also, I'm assuming you'll need a load resistor since they don't pull enough current to flash at the right rate. I've seen commercial ones for about £20 but can't you just make one yourself with the right resistance? Anyone know the ohms I'd need and what rating resistor? Where would you mount it in the circuit too?
Thanks |
Look on eBay, they had the resistors etc for LED's and they were only a couple of quid
I brought the motrax ones that came with resisitors. They stopped doing this now making you buy thier electronic relay! To be honest, i would stick with std bulbed indicators. They give a wide dispertion of light and can be seen at a greater angle.
Here's mine which I got from www.louis.de
They're quite nice and surprisingly visible. I didn't bother with resistors so they flash pretty fast (even faster when I mounted my undertray with integrated LED flashers) Still works though ![]() pic: ![]() |
Check Bandit Mania they do the built in cators mod, ie replaces the park lights. I think better than the LED, but that's my choice. Else Motrax do some nice ones.
I got resistors from Maplins £0.98 next day delivery £2.50 ![]() |
i've got the motrax ones and they are very bright and got my resistors from hein gericke same ones as e-bay but only £2 each and they work fine.
I've got Motrax indicators & 50p resistors from Maplins - no problems (famous last words....)
2000 - 2004 SV650S 2004 - 2009 SV1000S 2009 - 2013 Triumph Sprint ST1050 2013 - 2016 Triumph Explorer 1200 2016 - Ducati Multistrada DVT S ![]() |
#9 |
HG do resistors too, £2 each i think - nice big ones in a metal housing with mounting holes.
I've tried to replace my front indicators with LED ones and I still haven't found any i'm happy with - just not bright enough from the sides ![]()
Silver SV650SK3, Fuel exhaust |
Remove front indicators space -Move indicators in headlights | JanGoris | SV Talk, Tuning & Tweaking | 5 | 19-04-06 09:27 PM |
Which indicators? | aimhamilton | Bikes - Talk & Issues | 7 | 01-04-06 04:57 PM |
Indicators | mike_b | Stuff Wanted | 2 | 13-01-06 02:03 PM |
Indicators | enabb | For Sale - SV's and SV related items | 2 | 11-12-05 10:42 PM |
gsxr 600 indicators and sv k5 indicators (put down - drop) | swamp | SV Talk, Tuning & Tweaking | 3 | 03-04-05 02:25 PM |
