Old 12-08-05, 11:43 PM   #1
TSM
The Sick Man
TSM's Avatar
Default Warning on FIAMM horn convertion
Anyone had the FIAMM horns fall off their bike?
Well i have, 1300 miles into my holiday, it seems like one of the brackets suffered metal fatigue and broke leaving the horn hanging by one wire.
I noticed when i came off the motorway into the petrol station and could not get full lock as the horn was stuck between the forks and radiator.
Any ideas why this happened? Probably an idea for people to check just incase.
Old 13-08-05, 12:28 PM   #2
I thought the stock brackets looked a little flimsy so I built my own.
Actually that's a lie, I didn't notice there were brackets in the box so I built my own then found the stock ones But still, I think it worked out better. Basically you've got quite a heavy item on the end of a lightweight bracket, add loads of vibration and occasional heavy shocks and it's a prime metal fatigue situation. Where do you have them, radiator bolts?
Old 13-08-05, 06:05 PM   #3
TSM
The Sick Man
TSM's Avatar
yep, behind fairing on radiator.
The stock peice of metal that was in the packet is 2mm thick, i thought that was good.
Old 14-08-05, 01:26 AM   #4
r they good
I hat the horn on the SV
I seen at M and P they are a tenner
high note or low note?
easy to fit an wire up??
u remove the old on yeah?
Old 14-08-05, 11:58 AM   #5
The shell-type ones (ie not big long horns, wee curly ones) are excellent, and easy enough to fit... I went with one high and one low, which sounds horrible and therefore should be quite effective. The wiring took me a while, mainly because the directions supplied were a load of rubbish! So I binned them and did it by common sense. You can keep your old horn but I'd already removed it for the GSXR front so I didn't have that option. Basically I just put the relay across where the old horn was in the wiring, and ran new cables from the battery. You don't need to ignition switch it because the original horn was ignition switched.
Halfords sell the 2 FIAMMs as a pair under the Ring brand- so do Demon Tweeks- and the addition of the Ring fitment kit made it basically a piece of cake- comes with loads of wire with pre-fitted butt terminals for hte horn and relay contacts.
And I just hung them off the top radiator bolts, easy to do. The only bad bit is the testing- I had a bad solder in one of my cables and so I had to do a lot of test honking, which with 139db horns in a small garage is quite bad news
Old 14-08-05, 12:22 PM   #6
might give it a go then....
cheers for the info
Old 14-08-05, 12:26 PM   #7
TSM
The Sick Man
TSM's Avatar
I think the wiring kit i bought was listed as a Fog light wiring kit, i just chucked the switch and used the wire, fuse & relay.
I cant remember if they did a horn kit that came with all the wires and relays that you needed.
FIAMM Horn question Ceri JC SV Talk, Tuning & Tweaking 11 18-10-07 06:26 PM
FIAMM Horn question JeremySV650 SV Talk, Tuning & Tweaking 11 04-10-06 03:16 AM
fiamm horns jim@55 SV Talk, Tuning & Tweaking 10 29-11-05 07:45 PM
Horn jonhunt Bikes - Talk & Issues 29 12-09-05 12:30 PM
Does your FIAMM horn rattle? TSM SV Talk, Tuning & Tweaking 0 16-08-05 05:49 PM
