Old 15-08-05, 05:14 PM   #1
NAPA121
NAPA121's Avatar
Default Hamicad Grille Set
My dad & I have fitted the Hamicad grille set to my naked blue K4 SV650.
There is a black stiff rubber thing in kind of a half circle attached to the inside of the the forks that is rubbing against the grill set when the handle bars are turned.
Anyone know if this black rubber thing is important? Can I remove it? Can I cut it to make it shorter?
Has anyone else had the same issue when fitting the grill set?
The grill set does look the nuts..Very happy with it
Regards
Neil
Ex Owner of a lovely Naked Blue K4 SV650
Ex Owner of a Buell Lightning Long XB12Ss
Proud Owner of a Yamaha FZ1-N....Man this thing is quick
NAPA121 is offline   Reply With Quote
Old 15-08-05, 05:54 PM   #2
hall13uk
yes, not me personally but a good mate. i reckon you should just un screw the black bit, trim it & then fit it back on the bike
Old 16-08-05, 11:57 AM   #3
NAPA121
NAPA121's Avatar
What does it actually do though? There must be a reason why it's there or is it purely cosmetic?
Regards
Neil
Old 16-08-05, 12:32 PM   #4
uthaug
I think it is to protect the lower bearing for the steering head, keeping away water and grit thrown up from the front wheel.
I wondered about it too when I mounted my GSX-R forks, because the plastic protector didn't fit on them.
With the original forks the plastic hit the hamicad grill on mine too.
Not a big problem though.
Old 16-08-05, 04:35 PM   #5
redeye321
I have only just noticed it rubbing on the grill. Instead of taking it completly off you could always give the end a trim so they don't touch.
Old 16-08-05, 04:42 PM   #6
thor
Hmm, not noticed that on mine, but mine is a faired lady. I'll take a look tonight.
Old 21-08-05, 10:42 PM   #7
NAPA121
NAPA121's Avatar
So is the general opnion that it will be OK to trim it?
Just wish I knew what it was for?
Old 23-08-05, 11:02 AM   #8
beefcake
Hi
Are you referring to the black rubber guard (sits between the forks, quite near the top) that prevents all the crap being flung off of the front wheel getting up past the rad and into the lower head bearings? You should be ok to trim that back a little as you have got the fenda extenda to prevent the fling-off getting right up past the rad.
Old 24-08-05, 12:13 PM   #9
NAPA121
NAPA121's Avatar
Cheers Deano,
If it is to stop the crap being flung off of the front wheel and getting up past the rad and into the lower head bearings then as I have a fender extender why cant I just remove it?
The fender extender should give me the protection I need should it not?
aaaaaaaammmmmmmmmmmmmmmmmm !
Old 24-08-05, 01:37 PM   #10
beefcake
Thought I would surprise you! Made it difficult for me though as you changed your forum user name!
You could take it off, but I personally would just trim it back enough to give clearance of the rad grill cover. You want to afford as much protection to the bearings as possible, and trimming it back would be the more sensible thing to do. If you were to sell the bike you could always buy another plastic protector to replace the one you trimmed. If you remove the protector, I don't know how much Suzuki would charge you for new bearings.
Haaaammmmm, cheese and pickle purleeeeeeaaassseeeee!
Radiator Grille maultin SV Talk, Tuning & Tweaking 35 05-02-09 12:44 PM
oil cooler grille. Joshuaguru Bikes - Talk & Issues 1 12-07-07 08:01 PM
Hamicad TC3 SV Talk, Tuning & Tweaking 8 27-11-05 06:23 PM
Hamicad V's others? DeanoN SV Talk, Tuning & Tweaking 7 18-11-05 08:30 PM
Hamicad Dave C Bodywork 4 22-07-05 12:10 PM
