Old 23-08-05, 05:50 PM   #1
suzsv650
Default Rivets
One of the rivets have come loose on my Viper and fallen in the casing...
All the rivets on the slip on end have actually become so loose the end swivals round slightly...and some of the exhaust gases are leaking on to my swinging arm and causing black marks.
Anyone know what I can do apart from get a rivetting tool? ?? Help... please.
Old 23-08-05, 06:00 PM   #2
Other than get a rivetter?
No. Get a a riveting tool, and steel rivets, don't use aluminium they'll disappear in minutes.
Old 23-08-05, 06:22 PM   #3
suzsv650
know how much a riviting tool is ? from B&Q???
they are the tineyest rivets!
Old 23-08-05, 06:58 PM   #4
jim@55
i got a rivet gun and loads of rivets from lidl for a 5r so b+q will b about the same ,maybe a wee bit more ,10r tops???
Old 25-08-05, 07:32 AM   #5
Any rivetter that costs a fiver will have loads of aluminium rivets with it.
You need steel, aluminium won't last any time at all.
Old 25-08-05, 01:09 PM   #6
suzsv650
ive found a hand riviter in my local handyman shop. its £13 with 60 rivetsall small sizes around the right size.
is it as simple as drill out and use the gun kinda like a wall stapler??
if it is then it looks like il be buying a riveter tonight!
Old 25-08-05, 09:52 PM   #7
madmartyn
there is also stainless rivits need a preety good riviter though
Old 26-08-05, 02:06 AM   #8
IanG
IanG's Avatar
Also you would need to check for the type of rivet you are using as you can get rivets where the centre stem falls out once rivetted in place leaving a hole through the middle of the rivet , so you need to get the ones where the centre stem seals the middle, thus stopping the exhaust gases escaping.
2018 Honda CBR650FA
IanG is offline   Reply With Quote
Old 26-08-05, 08:36 PM   #9
madmartyn
otherwise known as a sealed rivit,
stainless rivets (stubbying ccc can) maclovin Bikes - Talk & Issues 1 20-12-08 03:02 PM
exhaust packing and rivets Lucas SV Talk, Tuning & Tweaking 2 24-10-08 10:45 AM
Where can I buy stainless steel pop rivets? Saint Matt Idle Banter 5 03-07-06 12:49 PM
Plastic snap in rivets mac SV Talk, Tuning & Tweaking 0 19-12-05 11:17 AM
Can I use a can that has rivetband/rivets missing? SpankyHam Bikes - Talk & Issues 3 24-05-05 09:34 PM
