Old 31-08-05, 06:11 PM   #1
daddy_sperm
Default front brake.
i am currently working at my brakes and was wondering :
When you squeeze your front brake lever how much does it move before you can no longer move it any further towards the bar?
I can squeeze mine to within about 30-40mm of the bar and was wondering if this was good enough? My lever is in position 1.
I know my friends R6 brakes solid just after the click for the light to be activated about 15mm from not on.
Old 31-08-05, 06:42 PM   #2
TSM
The Sick Man
TSM's Avatar
its not the distance you are looking at as that can be adjusted with the little reach dial on the brake.
Are they a solid feal, not spongy, does not when under presure return eventualy to the bar?
That is what i go by AFIK
Old 31-08-05, 06:45 PM   #3
R6 brakes are **** hot! sv's are a budget type you will notice a big difference.i have quite a lot of travel in my front brake lever.
Old 01-09-05, 07:18 PM   #4
muddycoffee
I have just given my front brake pads and calipers a good clean out and re-greasing and after I put them all back together I noticed the lever felt a little too solid and wooden when I was riding. So I bled the front brakes tonight and they are now much better, a good feel and better control. I have just got back from a small ride where I tested the brakes and the bike feels great..
WTD - rear brake lever, front brake lever, r & G crash bung, nik_nunez Stuff Wanted 0 17-10-08 08:27 PM
Front Brake - Rear Brake? Stradders Bikes - Talk & Issues 35 17-09-08 04:44 PM
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front brake not activating brake light properly SVeeedy Gonzales SV Talk, Tuning & Tweaking 5 27-02-07 12:09 PM
brake light flickers when the front brake pulled in - K4 dclifford SV Talk, Tuning & Tweaking 9 05-09-05 10:39 AM
