.........putting pointy clocks on a curvey?
Is it just a matter of rewiring or is it compleatly different? and if it is that different, why hasent someone devised a little black box to fix any gremlins? |
Big Ape has I believe....
Big Ape tell me the secrets *Jedi mind trick wave*
It can be done but there are a couple of functions that won't work, the driver for the tacho and the tempertaure gauge are part of the big box of 'leccy tricks that runs the FI and the ignition, myself and BigApe were going to try and construct something to make it all go but we ain't got 'round to it yet.
Do it before someone else does, could make you a fortune, i'd buy one
