Old 10-09-05, 03:31 PM   #1
TSM
The Sick Man
TSM's Avatar
Default Fuel mix screws
As the dynojet kit says, you should adjust the mixture screws on the SV, well i have tried. Seems like it has been touched before as the screw is damaged, i tried to turn it but it will not budge. How can i sort this out, is it because the screw is rubish brass and has deformed.
PS. what is the standard jetting on the SV, mine had 137.5 in there
Old 10-09-05, 04:40 PM   #2
21QUEST
21QUEST's Avatar
You've got to drill them out.
Ben
Nemo me impune lacessit.
Old 10-09-05, 04:43 PM   #3
TSM
The Sick Man
TSM's Avatar
Has anyone done this here, whats the best way.? Best to use a hand drill i guess.
Old 10-09-05, 04:45 PM   #4
Itching 2 go
Originally Posted by TSM
Has anyone done this here?
I haven't and I certainly wouldn't suggest doing it on my pc monitor, try holding it in a vice instead! :P
Old 10-09-05, 04:54 PM   #5
21QUEST
21QUEST's Avatar
Yep done it. You have to really careful. Start with the smallest drill bit(as tiny and go slowly and keep an eye on the dept.
Use a hand held vacumm cleaner to suck up the brass shavings as you go along.
Ben
Old 10-09-05, 08:27 PM   #6
And then after you've *****d it up, SV carbs are pretty cheap
Old 10-09-05, 10:05 PM   #7
21QUEST
21QUEST's Avatar
Ben
Old 10-09-05, 10:31 PM   #8
svrash
Wrap some tape around the drill bit about 3mm down and you won't drill any deeper then where the tape is ***super tip***
Old 10-09-05, 11:44 PM   #9
PeterM
Might want to try WD-40/RP7 or whatever you guys have for loosening threads before drilling away. The air screws shouldn't be that hard to move, unless someone has set them at the std 2 1/2 turns out and used threadlock (completely unnecessary).
Yes, 137.5 Mikuni mains are std from the factory too.
Old 10-09-05, 11:52 PM   #10
Since when was brass rubbish?
It's an entirely appropriate material for jets, mixture screws etc.
****ing suzuki ****ty screws davepreston SV Talk, Tuning & Tweaking 38 26-01-09 09:20 AM
Tight screws FG1 Idle Banter 12 18-01-09 11:33 AM
The screws. Stig Photos 19 12-01-08 12:22 AM
Bar End Weight Screws Banus SV Talk, Tuning & Tweaking 9 03-05-07 03:09 PM
tap and die set (AND SCREWS) Warren SV Talk, Tuning & Tweaking 15 06-07-06 08:56 PM
