Old 08-11-05, 09:48 PM   #1
TSM
The Sick Man
TSM's Avatar
Default My Front End
As i cant at the current time afford to sort out the plastics on the front end of the bike, i am going back to my old front end that i had at the start of the year, without all the gaffa tape there was. Basicly a SVS without plastics, plus because the mountings for the mirrors were way to dangerous i cut them off. As you can see i still yet dont know where the indicators will go, i will also have to find somewhere else to put the mirrors.
It was like this earlier in the year.
Old 08-11-05, 10:14 PM   #2
different- looks like its growing horns.
Old 08-11-05, 10:22 PM   #3
TSM
The Sick Man
TSM's Avatar
I was being silly there, i am going to weld some mirrors there.
Old 08-11-05, 10:31 PM   #4
u are running out of choices of where to put them.
Old 08-11-05, 10:40 PM   #5
TSM
The Sick Man
TSM's Avatar
yep i am, a SVS was only ment to have them on the fairing. Some nakid mirrors should be fine. I dont want to mount them to the handle bars like the nakid, i prefer fixed mirrors.
Then i will need to mount the indicators somewhere.
I will also have to move the loom and route it the same way the nakid had it between the forks & headstock.
Old 08-11-05, 11:14 PM   #6
carelesschucca
carelesschucca's Avatar
get the main body of the lights done Yellow, some bar end mirrors and your away...
My bike is in exactly the same state at the moment, and I kind like the way it so small... I keep thinking about going for the cafe racer look...
Old 08-11-05, 11:21 PM   #7
TSM
The Sick Man
TSM's Avatar
I might do that.
Some mock ups, crap but only with the pics i have available.
I would love the black frame with the yellow, but i will have to keep it stock with the yellow tank and rear plastics.
Old 09-11-05, 12:24 AM   #8
BIG Al
TSM where did all the lovely yellow plastic go anyway, you only fitted it back on mid year?
Old 09-11-05, 12:35 AM   #9
TSM
The Sick Man
TSM's Avatar
Was up on the Cat & Fiddle and crashed, damaged my back. The plastics are not to bad but i dont like things which are cracked or chipped. One side looks like it did not touch the ground but its gots a bit of gravel gashes on it, the other side has a split on the mirror part of the plastic where the front subframe twisted as it hit the barrier. Plus all the plastics at the back are stuffed & the rear subframe is twisted. Several other peices are damaged or twisted, the forks looks like they got off.
I am going to stay without any plastics & the front till i am a bit better on the cash front, then i will decide what to to.
Old 09-11-05, 10:21 AM   #10
Cloggsy
If it was me, I'd have left the plastics on... It looks butt-ugly without 'em IMHO
No offence intended
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front Discs (pair) for sv650 '99 curvy + Front wheel mikeSV Stuff Wanted 1 28-05-08 04:21 PM
Front Discs, For those with GSXR Front Ends on thier SV's Ter For Sale - SV's and SV related items 2 14-03-07 12:56 PM
SV650s 2000 model, yellow. I need front central and front right fairing. OdySV Stuff Wanted 0 25-02-07 04:47 PM
K3 radiator(any condition), front header pipe, FRONT END!!!! buttmunch Stuff Wanted 1 10-04-06 10:09 PM
