Old 09-11-05, 07:36 AM   #1
MavUK
Default Friday Afternoon / Monday Morning bike - HELP!!!!
Hey All,
Well just a few weeks after getting the SV back on the road (A lake in the tank and carbs was the reason last time, it now has a new filler cap and lives under a bike cover to stop this happenning again) I was nearly stuck again this morning...
Travelling at 60mph when suddenly it's very quiet and I'm starting to slow down, twist the throttle (reflex response to slowing down I think ) and nothing. Not good in the outside lane of the motorway...
By the time the bike slowed to about 45ish she suddenly started up again, was a bit rough for a few secs, then back to (hopefully) normal.
I'm thinking it can only be one of two things - fuel delivery issues (Tank is almost full, so plenty in there, even if it can't get to the carbs / engine) or ECU is on it's way out - as it was both cylinders and totally dead, not missing or anything, just absolutely nothing...
Really starting to get me down now. I love the SV, but with a 140km per day commute I need something I can have faith in...
Anyone got any ideas on what it could be? Or how I can fix it... Don't think I can really afford to start looking for another new bike after only a year of having this one...
TIA
Stu
Old 09-11-05, 08:02 AM   #2
mattSV
mattSV's Avatar
If you have had the fuel tank up, check that the fuel lines underneath have not been caught/kinked when you dropped it back down.
My dealer trapped a hose after my first service, which gave me the same symptoms that you described.
HTH
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 09-11-05, 08:10 AM   #3
MavUK
Cheers - hope this is the same... I'll have a check when I get home.
Thanks
Stu
Old 09-11-05, 08:24 AM   #4
SteveR
Any strange lights / conditions on clocks ?
I would guess the speedo was reading normally but the tacho was zero.
I wouldn't expect any other lights on though.
You might want to check sidestand cutout - is the sidestand held securely, and is the switch operating correctly ? Apart from that, I'd look for chafed / frayed wiring
Old 09-11-05, 08:37 AM   #5
mysteryjimbo
Ermmmmm two words.......
CARB
ICING
Possibly. If it was very cool (3-9c) and damp, theres your problem
Old 09-11-05, 08:38 AM   #6
MavUK
Sorry forgot to metion that - nothing else 'seemed' strange. The taco, strangely enough kept reading. I did a chack after to see how long it takes to return to 0 after I let go of the throttle in neutral and I think when the engine died the taco dropped in line with the engine speed, not with the as though it was suddenly getting no input.
I'll give the side stand a check at lunch and post back on it - but I think it's secure.
Stu
Old 09-11-05, 08:43 AM   #7
rictus01
rictus01's Avatar
Seeing as you've got the Classic shaped one, have you checked the rear subframe part of the loom ? lift it away from the bike as it is known to ware through on the inside. this can lead to some very strange things happening
Cheers Mark.
Old 09-11-05, 01:09 PM   #8
Ditto the above.
And:
Check the filler well drain isn't blocked and you haven't got water in the tank again, it's not the filler leaking that gets water in the tank, water lies in the filler well and when you open it it drops into the tank, it rarely looks like there's water 'rounf the filler as it's all dropped into your fuel...
Old 09-11-05, 02:13 PM   #9
SteveR
Stu
If your tacho was still showing revs, then I think we can discount ignition problems - and the sidestand switch. That leaves fuelling as the main suspect. Check not only fuel lines, but also the vacuum line to the fuel supply 'switch'
Old 09-11-05, 02:44 PM   #10
MavUK
Stu
OK - was my thinking...
If my scotoiler is working does that mean I can discount the vacumn line to the fuel switch - as it's hooked into this.
Stu
The Joys of Monday Morning... gettin2dizzy Idle Banter 27 15-09-08 03:48 PM
Friday afternoon rant Ed Idle Banter 18 15-06-07 10:02 PM
Something for a friday afternoon... Baph Idle Banter 8 16-12-06 09:59 AM
Friday Afternoon Joke Jabba Idle Banter 11 15-09-06 02:10 PM
Monday Morning Plonker Daimo Idle Banter 14 10-04-06 11:43 AM
