Any tips on doing:
1) Draining fuel and removing my tank. 2) Removing and refitting the fuel pump. All for a K3/Pointy tank... just wondering where to start, and the basic information. Ta.
SV650 K3 - Gone. Now a member of the SV650.org Kawasaki brigade! |
#2 | |
#3 | |
Alternatively you might like to remove the tank first, and turn that upside down, then when most of the fuel is out - it won't all go that way - turn the tank on it's side, remove the fuel pump assembly from the underside and let the rest drain out there.
#4 | ||
I tried that once! |
I found that, even when the fuel pump is removed, you won't get every last drop out of the tank - there'll still be a little bit sloshing around.
My fuel pump was half removed very quickly!! ![]() I wouldn't recommend using the same method though!!! ![]() |
#7 | ||
#8 | |
If it's going off to be painted and is going to be put in a paint oven, it would probably be a very bad idea to leave any fuel in the tank! ![]() You will also find that unless the tank is put back together and closed, that the fuel will eveporate rather quickly!! ![]() |
#9 | |
![]() Just kidding - PLEASE DON'T DO THIS |
#10 |
have you considered disconecting the fuel pipe from the carbs to the pump and pointing it towards a suitable container then turning your ignition on? If I am right the pump will try to prime the system but not get any back pressure so just pump all the fuel out.
Tips for riding in the ice | wtdafk | Bikes - Talk & Issues | 12 | 21-01-09 05:39 PM |
im goin for a job here any tips | leemole | Idle Banter | 7 | 25-10-07 04:41 PM |
Anybody got any tips on how to.......? | clodge | Idle Banter | 14 | 05-09-07 01:29 PM |
Interview tips | cuffy | Idle Banter | 32 | 30-10-06 05:55 PM |
Filtering tips | andyaikido | Bikes - Talk & Issues | 49 | 23-11-05 06:14 PM |
