Old 09-11-05, 05:21 PM   #1
leegriffiths128
Default Bikes a non starter -Help ?
Tail - lights weren't working, found problem and rejoined the seperated connector. Now the old girl won't start....turning over and fuel system seems to be priming when i switch her on but nothing more. Can't smell petrol so suspect a fuel problem ?
Checked fuses and they're ok but after that I'm lost.
Bike is a K3 fuel injected.
Any simple advice for a novice would be really appreciated peeps.....otherwise does anyone know a decent mechanic in the Wolverhampton area ??
Old 09-11-05, 05:32 PM   #2
Itching 2 go
I would put up a post to say how to fix her if I knew the problem sorry dude I am no help
Old 09-11-05, 06:50 PM   #3
Biker Biggles
Biker Biggles's Avatar
Did it fail straight after you fixed the tail light?If so you may have disturbed something or the wires you joined were wrong.Try disconnecting tail light again and starting from scratch.
Old 09-11-05, 06:50 PM   #4
TSM
The Sick Man
TSM's Avatar
Have you got an alarm installed??
Old 11-11-05, 05:13 PM   #5
leegriffiths128
Yeah..already tried disconnecting wires and no there is'nt an alarm fitted.
Further update is that there is no spark
Old 11-11-05, 05:55 PM   #6
RWR
there is a sensor in the back end to turn the fuel pump off when you crash if you have disturbed that it will not start,
Is there any messages up on your display?
Old 11-11-05, 06:30 PM   #7
leegriffiths128
Mmmm that sounds interesting. There is an 'FI' appear on the dash when I first turn on but that disappears after the bike has 'primed'
How can I check the sensor...whats it look like ?
Cheers v.much
Old 11-11-05, 06:52 PM   #8
RWR
Its a little black box held in a rubber clip it would have to be hanging off for this to cause the problem
When i fitted an Alloy subframe to my race my bike my m8 put it in upside down it took me ages to find out the problem. well actually somebody else found out what it was.
Old 11-11-05, 07:13 PM   #9
leegriffiths128
Would this cause the spark plugs to fail ?
Old 12-11-05, 09:50 AM   #10
Last Action Pimp
how about the battery or killswitch, basic but it happens
Non starter. AndyBrad SV Talk, Tuning & Tweaking 61 26-05-09 07:50 PM
non starter richiekuk SV Talk, Tuning & Tweaking 41 22-05-09 01:49 PM
non starter evertheoptimist SV Talk, Tuning & Tweaking 9 09-05-08 06:19 AM
Non-starter for ten... Bluewolf SV Talk, Tuning & Tweaking 6 23-08-07 09:21 AM
Non starter - help sticky-dizzle SV Talk, Tuning & Tweaking 11 12-04-07 02:38 AM
