Exhausts Post your own reviews, opinions and experiences on this subject.
Old 26-11-05, 06:36 PM   #1
TC3
Default Fitted CCC today
The CCC i got down the NEC is now on and all i can say is YEAH! Sounds pretty loud and deep without the baffle but not tried it with the baffle as it is not offensivly loud.
Drilling out the rivet that holds the baffle was easy but the baffle needed a good push from the other end to get it out and to refit i have to use a load of force. I would have to remove the can again as it just is to tight to come out easily, even with the use of pliers. Sounds a bit odd as i thought it was easy to slot in and out from what i have read in posts. May mail CCC and see whats up with that
Those who still have the original can.....the s/s oval is a real good buy on e bay
Old 26-11-05, 07:09 PM   #2
i was'nt aware you had to drill out the rivet for the baffel, they are hard to get out at first because they silicone the baffle in to make a seal well this is how my scorpion was.
Old 27-11-05, 10:07 AM   #3
jim@55
my baffle comes in/out very easy,just hand pressure is enough.i can just put it in/pull it out as req(ooeerr missus).the rivet just stays out now ,i dont need it .the baffle just pushes in no prob .i keep the baffle under the seat just in case ,seconds to fit ,.sounds good eh????
Old 27-11-05, 06:47 PM   #4
TC3
I have the oval can and a mate got the same at same time and on both it is real hard getting baffle in and impossible getting it out without force from INSIDE the can meaning can needs removing. We went for our first real rides today and i gotta say WOW it sounds so loud and deep. My mate has a bandit and moaned mine sounded so much better and i just said it was a V Twin thing......
Old 27-11-05, 08:12 PM   #5
DeanoN
I found the first time I took the baffle out it was a bit tight but it pushes in and out ok by hand now, not that i've ever riden with it in, just get it out from under the seat now and then to show people who are interested the difference in sound.
Old 28-11-05, 04:30 PM   #6
TC3
CCC e mailed me back and said to try some copper slip so hopefully that will make it slide in and out easier ...
Old 28-11-05, 10:22 PM   #7
Iain51
Put the baffle back in
Old 05-12-05, 03:59 PM   #8
TC3
I live in a close......early Sunday morning rides are gonna need the baffle in till i get out of the area!
Old 05-12-05, 04:18 PM   #9
Skip
Skip's Avatar
I have yet to remove my baffle - still enjoying it with it in place!
But then it did take me 8 months of SV ownership to fit a can in the first place!
'81 Honda H100A
'18 Honda MSX125 (Grom)
Old 07-12-05, 07:35 PM   #10
madmal
thanks for tip, just put oval ccc on mine and found baffle tight to remove. worth keeping with you just in case you have to plop it in- "can i just have a look at your can sonny", "why of course". does sound good removed though.
New Lowers fitted K3 today markryker Photos 20 13-04-08 10:04 PM
admin fitted my T3 sliders today Ed Photos 21 11-03-08 01:56 PM
New Lowers fitted today markryker The Border Patrol 6 04-03-08 05:37 PM
Look what I received and fitted today :) (Video) M1TCH Exhausts 9 11-04-07 09:25 PM
scorpion stainless fitted today goldengraemes Exhausts 8 13-03-05 11:18 PM
