Old 01-12-05, 12:39 AM   #1
sprocket
Default Dash Lights
My dash lights dont seem to be working, I've taken them out and checked them, one needed replaceing. These are the 3 lights that light up the speedo and tacho. Does anyone know of any faults in the system that could cause this.
Also my sidelights arn't working, is this a seperate bulb in the main headlight unit or is it a wiring thing?
Thanks in advance.
Old 01-12-05, 12:50 AM   #2
BURNER
Check your earth.
you might have a live feed but no earth.
Do you have a voltmeter or summat?
Old 01-12-05, 12:52 AM   #3
sprocket
yeah got a voltmeter, might have to have a better look at it tomoz
Old 01-12-05, 01:59 AM   #4
TSM
The Sick Man
TSM's Avatar
does your front side light turn on (the little one on the top of the main lights)?
Check the fuses, unconnect the mid loom connectors to the front lights and clocks and make sure its not totaly corroded, you may need to clean the terminals.
I will check the wiring diagram tommorow if i can.
No Speedo, No Lights, No Rev Counter, No Dash. JamesMio SV Talk, Tuning & Tweaking 47 06-04-09 11:24 AM
no lights on dash, nadda dizzyblonde SV Talk, Tuning & Tweaking 13 28-09-08 05:16 PM
Dash lights Question Rick-UK SV Talk, Tuning & Tweaking 3 07-12-06 08:59 AM
LED dash lights pics svrash SV Talk, Tuning & Tweaking 9 24-04-06 11:12 PM
SV 99-02 dash lights sprocket SV Talk, Tuning & Tweaking 5 31-08-05 12:38 PM
