Old 01-12-05, 09:40 AM   #1
Alex Oliver
Default gixer rear shock
Can any one tell me whether the GSXR 600 rear shock will bolt straight onto a 99 svs?
I'm lead to understand that the 2001 - on ones do but I've only read conjecture.
I know on the US site there is a Race firm that revamp them specifically for bike & rider but I don't know if that includes changing fittings. I also wonder if there's room for the adjuster bits atop the gixer unit.
Old 01-12-05, 10:19 AM   #2
TSM
The Sick Man
TSM's Avatar
don think so, srad ones are what you need for curveys. They are a tad old so have a look at zx686 shocks.
Old 01-12-05, 07:23 PM   #3
sprocket
Do a search on the site theres quite a few charts floating around which tell you the length of all the different shocks so you can gauge which size is best for your bike and weight. With 9 out of 10 shocks you'll need to cut the battery box though.
Old 01-12-05, 07:28 PM   #4
TSM
The Sick Man
TSM's Avatar
The worst shock for fittment is a ZX686 (the year i dont know), one of the series have the oil resovoir pointing towards the back of the bike and angled a tad up, it makes it impossable for the battery to be under the front seat and will have to be relocated to the rear seat, and the tool kit goes under the front seat (leaving two allen keys under the rear seat to get to the tool kit in the front). Its an ar$e, but works well.
Old 02-12-05, 08:25 AM   #5
PeterM
I beg to differ on that one mate. I've got a ZX636 shock fitted, yes the battery box needed a little trimming, and the battery is still under the front seat. It is not completely upright but fits nicely on top of a little platform, keeping it off the shock resevoir.
Alternatively, a battery from an R1 will fit in the original battery position as it is a thinner battery.
Old 02-12-05, 11:47 AM   #6
TSM
The Sick Man
TSM's Avatar
PeterM: There are diffrent ZX636 shocks, there is one with a larger resovoir than the other and i have the larger one (one model looks the same as GSXR shock the other the res points backwards and upwards. I tried every way possable to fit it, it just would not fit very well. Even with it resting on the shock the seat would not close.
The general concensous is not to change the battery to one with a lower rating (as the R1 is i beleave) in the UK as we use diffrent oil from warmer climates and increases the starting load and also our cold spells could easly kill the battery more often than normal.
Old 02-12-05, 09:33 PM   #7
Maybe a useful link... www.svraceshop.com. They do a rebuilt GSXR shock with a revalve, lengthen, and sometimes new spring, for the SV. $340, which comes to about £200. They also sell ally brackets to replace the normal tank hinge, makes reservoired shocks easier to install.
Old 03-12-05, 01:48 PM   #8
21QUEST
21QUEST's Avatar
I'll say get a proper shock(Emulsion type). I'm deciding on a shock myself for my other bike.
Have a look at prices for the WP or Technoflex.
You can get the ones with just a rebound adjuster. With the Technoflex (think I'm correct) it's built to the spec you want ie length , correct spring , etc.
I'll try and get some phone numbers for you if you decide to go that route.
Also Vic Lamb Developements are having 10% off the WP shock but there is another dealer that might be cheaper.
Ben
Nemo me impune lacessit.
Old 03-12-05, 11:23 PM   #9
sprocket
Ohhhh I was considering a WP shock for the SV what sort of prices are you looking at them then?
Old 03-12-05, 11:44 PM   #10
Drop Careless Chukka a bell, he's got one for the SV... They've got a good name. (well, they've got a terrible name- White Power? Jeezus...)
I like my Ohlins It was cheap and it looks brilliant. Works not too bad either...
Ally Rear brake caliper torque arm ...from GIXER SRAD 21QUEST For Sale - SV's and SV related items 9 11-02-08 12:12 AM
Gixer 600 K4 shock in a pointy Lozzo SV Talk, Tuning & Tweaking 2 18-01-08 11:23 PM
Gixer 600 Rear shock PaulyMac SV Talk, Tuning & Tweaking 5 18-09-06 08:43 AM
gixer shock k1-k2 good condition 200 miles only stumpy1 For Sale - SV's and SV related items 5 26-07-06 01:49 PM
SV Gixer shock red5 SV Talk, Tuning & Tweaking 12 13-05-06 07:34 AM
