Getting some Motrax led arrow indicators for xmas and was wondering those of you that do have led indys....have you had much of a problem with the flash rate? I have seen replacement flash relays to correct this but it seems on the pointy the relay used for the turn signal is combined with the relay for the side stand i think and so i am not sure i can replace the relay if i need to.
Any experience or thoughts you have on this are welcome ![]() |
Knob faced knobster
what i did on my curvey was fitted the individual resistors that you can buy from hein gerickes for a couple of quid each, you'll need four. i souldered them in before i fitted the indies.
2001 SV650 in shimmerin green, Not broken anymore |
ive seen those led arrow indicators in hg,was wondering ,as they have electrical connectors on the end of the wires are they a straight plugnplay thing ,??or would you have to put a resistor in
#4 | |
Knob faced knobster
resistors is the only way to go on pointy's as the relay is in built.
Ok thanks guys....resistors it is then
You can fit the alternative relay to a pointy, and a curvy too - they share the same flasher unit/starter lockout relay combination. All you need to do is remove the indicator wiring from the connector block in which the relay fits and connect them direct to the new flasher unit, which you can fit next to the original.
#8 | |
#9 |
Would much prefer to solder cheap resistors in. Someone on here used 10w 10 ohms resistors from Maplins....i have found the 10 w wire wound resistors here
http://www.maplin.co.uk/module.aspx?ModuleNo=2181&doy= but can someone tell me which one is 10 ohms? |
#10 | |
![]() H10R is 10Watt 10 ohm. About 25p each - get 4, wire each one in parallel, piece of **** ![]()
2000 - 2004 SV650S 2004 - 2009 SV1000S 2009 - 2013 Triumph Sprint ST1050 2013 - 2016 Triumph Explorer 1200 2016 - Ducati Multistrada DVT S ![]() |
LED Flash rate relays... | DF! | SV Talk, Tuning & Tweaking | 4 | 17-09-08 06:47 AM |
Not the normal type of indicator flash rate problem.... | DarrenSV650S | SV Talk, Tuning & Tweaking | 11 | 03-07-08 06:42 PM |
LED indicators and flash rate | Quiff Wichard | Bikes - Talk & Issues | 12 | 28-05-06 11:09 AM |
LED Indicators - Flash Rate | mastiffmat | SV Talk, Tuning & Tweaking | 3 | 09-11-05 04:54 PM |
Flash rate Problems?? (Non LED) | Sledgehammer | SV Talk, Tuning & Tweaking | 7 | 15-08-05 08:45 PM |
