Old 21-12-05, 01:02 PM   #1
Samurai
Default Oil change!!!
I need to do an oil change on my K3 Naked Sv650 and don't know if there is anything special i need to do this or chan i just drain the oil, refill and replace the filter.
Old 21-12-05, 01:19 PM   #2
Yep, that's about it. But not in that order, it goes:
Drain oil, replace filter, then refill.
Old 21-12-05, 01:22 PM   #3
Samurai
Thanks, glad i don't need anything else, thought knowing my luck would involve alot more.
Old 21-12-05, 02:23 PM   #4
chazzyb
Usually best done with the engine still moderately warm, as the old oil will drain down more quickly.
Old 21-12-05, 02:24 PM   #5
jonboy
Yes somewhat necessary .
Old 21-12-05, 03:20 PM   #6
ash
Don't forget a new sump washer.
I know not everybody does, but the only person I know personally who didn't had a leak and had to start from scratch.... for the sake of 35p !!
Old 21-12-05, 03:41 PM   #7
jonboy
I don't and still have the original washer at 30k miles and approx ten oil changes .
Old 21-12-05, 03:48 PM   #8
jon
Take it from me, the anticlockwise to loosen reverses when it's upside down....
How i didn't strip the thread and ruin the sump is beyond me.
Old 21-12-05, 04:33 PM   #9
RandyO
there's much more to a service than changing the oil
cleaning lubing adjusting, cables, linkage, lever pinch bolts, chain, check fasteners, etc.
Old 21-12-05, 04:42 PM   #10
jonboy
Yes but that hardly takes a second ot two and should also be done on a regular basis. Methinks you've paid a fortune in the past due to your near evangelical praise of the Randy Mechanic (no jokes folks ). You could have done it yourself sooooo much cheaper.
Spend £117 & change on bike - but no change in bike pete m Bikes - Talk & Issues 10 06-05-09 12:26 PM
Just done an oil change! Kinvig SV Talk, Tuning & Tweaking 8 14-10-06 04:56 PM
Change in weather= Change in diet Dicky Ticker Idle Banter 5 15-08-06 06:51 PM
Oil Filter Change with every oil change? Ceri JC SV Talk, Tuning & Tweaking 2 22-11-04 06:02 PM
