Old 10-01-06, 12:43 PM   #1
pepe
Default Autocom fitting to K3
I'm fitting an autocom Active 7 unit to my bike this weekend and was hoping to download the 650s k3 electrical manual before I started but I can't download for some reason. I want to connect it to the numberplate light and was wondering if anyone knows which colored cable I should be connecting it to ? I know that the neg connects to the battery but just want to make sure about connecting the pos to the right cable .
Thanks,
Glenn
Old 10-01-06, 12:45 PM   #2
BillyC
BillyC's Avatar
There should be a spare position in the Fuse box - which is activated by the ignition.
Old 10-01-06, 01:16 PM   #3
thor
Where did everyone place theirs? I tried to get it in an area that could be easily adjusted, and where the input wires would reach my tank from the front. Turned out that under the side panel on the right was the only place that would work for me...
Old 10-01-06, 01:17 PM   #4
mattSV
mattSV's Avatar
Mine is attached via velcro under the pillion seat to the rail on the right (as you sit on the bike). Bit of a squeeze, however it is out of the way but still accessible if it needs adjusting
From memory, I fitted it as follows:-
1) Remove pillion & rider seat.
2) Run -ve lead to battery - ready for connection (fit a crimped/soldered eye first)
3) Run +ve lead around the rear of the pillion seat frame to connect to rear light cable (grey wire on left under pillion seat)
4) Ensure battery is disconnected then split grey wire & splice/solder +ve to grey wire
5) Reconnect battery and ensure that rear light still comes on with ignition - if not, you are fiicked.
6) Route the rider headset cable under the riders seat and bring it out somewhere convenient next to the tank - mine comes out right at the front of the rider's seat.
7) Connect headset and speak into mike to ensure all is working ok
Tidy up cables with tie wraps
HTH
Matt
2000 - 2004 SV650S
2004 - 2009 SV1000S
Old 10-01-06, 01:22 PM   #5
pepe
Cheers BillyC,
sounds a lot easier than connecting to the light. And just to clarify, all I need to do is connect the autocom unit straight into the spare fuse position ie no need to connect the neg to the battery as it's already connected via the spare position ?
Also this wont interfere with the bike electrics, I have a data tool alarm fitted so need to check that it's not connected in the spare position.
Sorry but don't know much about electrics ( as you may have guessed ! )
Thanks for your help
Glenn
Old 10-01-06, 02:23 PM   #6
pepe
Cheers mattSV,
will hopefully be fitted this weekend.
Old 10-01-06, 06:06 PM   #7
rob13
were these all purchased in the half price sale? better get my skates on if i want one - there aint many left
Old 10-01-06, 07:34 PM   #8
pepe
robchester,
I got mine last weekend for £75 from ''onyerbike''. They have a website etc but not sure how many they had left.
Old 11-01-06, 01:15 AM   #9
rob13
onyerbike sold out of active kits. trying a couple more places
Old 14-01-06, 04:29 PM   #10
pepe
Fitted it today and all working fine , seems like a great bit off kit which will come in very handy for when me and my mate go over to France/Spain for two weeks this summer Just need to fit his tomorrow.
Thanls again for your advice .
Glenn
Autocom helmet fitting Miles Bikes - Talk & Issues 7 25-03-09 10:33 PM
Fitting an autocom thingy on the bike... valleyboy SV Talk, Tuning & Tweaking 3 15-07-05 08:31 AM
Fitting an Autocom system Baldyman SV Talk, Tuning & Tweaking 23 23-06-05 11:02 AM
autocom TSM Bikes - Talk & Issues 6 06-04-05 02:39 PM
Autocom Jelster Bikes - Talk & Issues 3 28-02-05 12:47 PM
