20-01-06, 06:27 PM | #1 |
Squeeky front wheel..
After my off last month the bike sat for about a month before moving again. the first time I tried to move it, it seemed quite stiff but seemed to be free up so I assumed it was just from being left.
Now when I am going at low speeds (<10mph) the front wheel seems to squeek a fair bit then stop when the speed rises. I don't think it is the brakes as I don't have the front brake on when it happens. I am just wondering what it could be as I am a little bit paranoid. |
21-01-06, 11:46 AM | #2 |
Probably front brakes sticking on slightly.You need to take the calipers off and clean the pistons.Make sure they can be pushed back into the calipers after cleaning.This needs doing often,and after bike has stood a while will almost certainly be your culprit.
23-01-06, 10:12 AM | #3 |
Cheers.
Is this an easy job for novice mechanic or would I be better getting someone a bit handier to do it? |
26-01-06, 10:09 AM | #4 |
im no expert or anything and i managed to get my calipers of my old bike that was only a nsr but i imagen it would be pretty much the same, im sure there would be sum step by step instructions on the net sumwhere that could help 2, not v nice to do it in this weather tho the pistons can b a bit fidly with cold hands
26-01-06, 09:00 PM | #5 |
Check that a mouse has not crawled up one of the fork legs!
26-01-06, 09:09 PM | #6 |
Ho Ho
My sister heard a squeak when driving her VW Golf(remember that advert?)and found she had mice living in it.Seems they moved in as it was dry and warm,and the local cats could'nt get in.
28-01-06, 04:38 PM | #7 |
big rust hole then?
SV650 Front Wheel - Do any other Suzuki models use the same front wheel? | williamturner1 | SV Talk, Tuning & Tweaking | 11 | 30-05-10 02:31 PM |
Front Discs (pair) for sv650 '99 curvy + Front wheel | mikeSV | Stuff Wanted | 1 | 28-05-08 04:21 PM |
Getting the front wheel up | ClemsonSV | Bikes - Talk & Issues | 14 | 16-07-07 08:23 PM |
K4 Front Wheel | Hayezy | SV Talk, Tuning & Tweaking | 2 | 16-08-06 01:45 PM |
front wheel maintenance ?? need to prop up front wheel etc | valleyboy | SV Talk, Tuning & Tweaking | 2 | 26-08-05 07:50 PM |
