Old 20-01-06, 09:01 PM   #1
GooseSVSK2
Default anyone know the lifespan of the clutch, should I change it?
Got the big service coming up (well a little past it..) seeing as the things going to be opened up for the valve checks, should I get the clutch done at the same time. How long do these things last? Have had no problems with the clutch( only the odd scrapey noise when very cold weather) but plan on keeping the bike for another two years, sureley the clutch wont last all that time?
Any advice gratefully recieved,
Cheers,
Si
Old 20-01-06, 09:41 PM   #2
jonboy
Default Re: anyone know the lifespan of the clutch, should I change
The valve shim checks don't need anything opened up other than the small timing hole, so don't let anyone fool you there. The clutch is pretty bullet proof unless it's violently abused (someone on here take note ) so it shouldn't need replacing unless the engine's done maybe 50-100k miles.
...but plan on keeping the bike for another two years, sureley the clutch wont last all that time?
Why on earth not?
Old 20-01-06, 09:47 PM   #3
GooseSVSK2
Default Ta
Thanks John thats a weight off my mind. hope to make it over to soho one of these fridays
What is the Average Chain Lifespan? COLZO SV Talk, Tuning & Tweaking 16 29-01-09 08:24 PM
Steering head bearings - lifespan? Fizzy Fish SV Talk, Tuning & Tweaking 6 30-06-08 06:37 PM
Clutch Problem? Cutting off when releasing clutch in first gear! puthsardarade SV Talk, Tuning & Tweaking 15 09-01-08 09:42 PM
How long is a helmets lifespan? Monkey6879 Bikes - Talk & Issues 28 05-02-07 01:11 AM
Clear clutch covers to see the clutch spin while running. TLRMAN SV Talk, Tuning & Tweaking 13 01-11-04 02:18 PM
