Old 21-01-06, 12:23 AM   #1
Foey
Default cure for fast flash
Just fitted some new indicators to the front of my SV & it's caused them to flash too fast, can the motrax relay be fitted to a pointy as the suzuki relay incorporates the sidestand relay as well or is there another way to slow the flash rate, if so what is it, where can i get it etc etc.
Many thanks.
Old 21-01-06, 12:31 AM   #2
Carsick
if you undo the wires from the original flasher then yes, it can be used.
Simplest, cheapest and most reversible way is to put resisters in. Search the forums for info on that.
Old 21-01-06, 12:40 AM   #3
Foey
Thanks for that mate, will have a search.
Old 21-01-06, 07:42 AM   #4
TC3
I used resistors...u need 4 at 25p each from Maplin. Dead easy to fit if u have a solder iron and if not a good excuse to get one rather than spend 20 quid on the Motrax crap
hangover cure AndyBrad Idle Banter 19 21-03-09 09:34 PM
FLASH FLASH...Q for the police people maff Idle Banter 16 04-10-08 07:03 PM
Prevention is better than a Cure...... SoulKiss Bikes - Talk & Issues 9 22-02-08 04:50 PM
Traffic Light Cameras ..Flash Flash ? Eggspit Bikes - Talk & Issues 28 23-11-05 11:02 PM
