Howdy,
Anyone know off hand what engine temp the fan should kick on at? I've just replaced a radiator on a K3 and filled it up with coolant and left it running to see if the fan was ok but it wasn't coming on. I let it run until about 106 degrees. Anyone any ideas? Ceers, Rob. |
The Sick Man
Have you bridged the temp sensor to see if the fan comes on?
OTR: KTM 690 Duke R 2015 Full Akro SIDELINE: Kwak ZX636 A1P 2002, Red, R&G's, Yoshi, Double Bubble Screen GONE: Kwak ZX-7R P1, Full Akro, Undertray, Screen GONE: SV650S K2 Very Bruised & Without Fairing, Motovation Frame Sliders, R&G Ally Sprocket Toe Protector, HEL 2 Line Setup, GSXR K1 600 RWU Forks, Barnett Clutch & Springs, Penske 8981 Shock, Gilles Ti Rearsets, Steel Barends, Scottoiler, AFAM Chain & Sprockets, Twin FIAMM Horns, Skidmarx Bellypan, Full Micron Zeta Steel System, Cut down undertay. Forum Problems & Information / Site Suggestions |
#3 | |
Have you burped the system as you could well have an air pocket around the sensor which means it wont work as it should.
#5 | |
Cheers for the replies! Yup I bridged the temp sensor and the fan works no problems. How exactly do I burp the coolant system? There's definitely enough coolant in the system, it's up just underneath the filler cap (its a naked sv so no separate coolant resevoir).
Again cheers for the help! Rob. |
The Sick Man
Little screw on the water pump.
I have the same problem. Bought second hand temp sensor from ebay and still no joy. Works fine when I bridge it. I will try 'burping' tonight. Anyone know where to find cheap new temp sensors!? Suzuki are ripping us off at £40 a go.
Any other hints on this? |
#9 |
The naked one does have a coolant reservoir. I've found just running it (cold) for a few seconds with the cap off gets all the air out, also rock it from side to side a bit.
#10 |
I don't think that my fan used to come on until the engine was over 100, the only time it ever came on in this country from memory was riding round London on a hot day. 106 does sound like it should be on though.
At what temp should the fan cut in? | Unlucky4some | SV Talk, Tuning & Tweaking | 21 | 19-10-08 03:32 AM |
Temp Display | bobit69 | SV Talk, Tuning & Tweaking | 10 | 30-08-07 03:37 PM |
Question on the temp | aday2end | Bikes - Talk & Issues | 6 | 15-03-07 04:02 PM |
Temp Gauge? | yvo6 | SV Talk, Tuning & Tweaking | 11 | 09-02-07 11:16 PM |
Where could i put a temp sensor? | svrash | SV Talk, Tuning & Tweaking | 17 | 13-01-07 12:16 AM |
