Old 30-01-06, 08:57 PM   #1
dnicholson99
Junior Member
dnicholson99's Avatar
Default 2000 Model Back Brake
Anybody got any tips for bleeding the back brake? Mine is pretty crap even though I have repeatedly bled it. Everything that should move seems to, it’s just it seems to be very indirect compared to the front.
dnicholson99 is offline   Reply With Quote
Old 30-01-06, 09:03 PM   #2
Scoobs
ARe you sure it is the brake that needs bleeding and not contaminated pads? If the lever feels firm when applied it may be this.
If it feels spongy it probably needs to be bled. Make sure that there are no leaks in the system. Hang a weight on the foot brake lever to pressurise the system and leave it over night. Check the hose and the banjos in the morning for signs of leakage. Also any air that is present in the system (if there aren't any leaks) will have risen to the reservoir making the brake firmer anyhow.
If there are no leaks and you do need to bleed the brakes, make sure that the reservoir is kept topped up at all times and pump the lever slowly.
Old 30-01-06, 09:21 PM   #3
Are you bleeding both nipples?
It's surprising how many people miss it.
Old 30-01-06, 09:24 PM   #4
jonboy
Well, quite!
Old 30-01-06, 09:34 PM   #5
dnicholson99
Junior Member
yes I got the hidden one
Engine from a 2000 model yorkshiregooner For Sale - SV's and SV related items 3 26-05-06 08:17 AM
2002 wheel fit 2000 model? kavana77 SV Talk, Tuning & Tweaking 3 09-09-05 10:21 AM
Will the adjustable forks from the K2 model fit a 2000? the oaf SV Talk, Tuning & Tweaking 4 02-06-05 08:44 AM
Derestrict 2000 SY model HELP! sv182 SV Talk, Tuning & Tweaking 44 12-02-05 12:00 AM
