View Poll Results: Am I talking Twaddle
Yay 5 23.81%
Nay 6 28.57%
wibble 10 47.62%
Voters: 21. You may not vote on this poll
Old 03-02-06, 10:52 PM   #1
Caddy2000
Default Powercommand or not to Powercommand
Okay,
I've just read the thread on the K+N issue, and it made me think:
Even if I'm running a standard setup (can and filter), would I benefit from a power commander?
My train of thought goes a bit like this: The general use of a power commander is to get an engine to chuck out a couple of extra BHP, but what does it do?
To my mind it replaces the engine map that suzuki has decided is best for the bike.
Suzuki have a couple of problems to put up with when sticking a 'budget' bike (okay, not meant to upset anyone, but we are hardly talking £10k+ are we) on the world market: 1) They need one map that will work on every single bike they chuck out of that model and 2) they need a map that will work on almost any fuel from round the world (Landrover have the same issue with the Defender which is why it seems to have so much less power than other 4x4s)
So with a power commander you can tailor the mapping to your bike, can't you? And to the type of fuel you use whether it be standard or super
Has this made any sense, or are there huge holes? Let us know, it's how we all learn
Old 03-02-06, 10:56 PM   #2
hall13uk
i want a power commander, but i can't afford one yet. i have an akrapovic full system
Old 03-02-06, 11:02 PM   #3
You're definately on the right lines... But IMO a PC is a very expensive luxury unless you've done a lot of work on the bike and really want to get the most out of it- remember, don't just consider the price of the box- also take into accountthe price of the setup.
If you can get to a dyno place with a yoshi or ideally teka box, they can reflash your standard ECU instead- much cheaper, and not much less good by all accounts. All these newfangled FI things confuse I, I like fuelling that you can fix with a screwdriver.
Old 03-02-06, 11:04 PM   #4
TSM
The Sick Man
TSM's Avatar
The SV ecu can be tweeked with a Tekka or Yoshi box anyway.
General consenus is that a PC is not worth it for a road sv, even with mods.
Just get a dyno shop with the right kit and they will tweek the standard ECU.
Its much cheeper, way cheeper.
Old 03-02-06, 11:07 PM   #5
Caddy2000
You should try setting up a Matchless then The James was easier though, I just fiddled with the strength of the mix.
Luckily my SV came with a PC and I think with the Quill and the K+N it might just need it - although I think it does need to go back and be re-done as I'm not happy with it.
Why did we leave carbs behind?
Icing and fuel consumption outstanding...
Old 03-02-06, 11:23 PM   #6
Emissions and fashion, IMO
Old 03-02-06, 11:46 PM   #7
latts650s
i have got a power commander on my svs k5 with standered filter and the bike runs good.would fitting a k&n filter do any better.the can i have is ccc can.or the other thing is getting the ecu remap to make the bike run better without the pc,does anyone know were u can get this done.i have heard that steve jordan motorcycles can do it when i had some work done there.
ps i am tinking of sellin the pc to free up some spare cash.
Old 03-02-06, 11:56 PM   #8
rictus01
rictus01's Avatar
If you can get to a dyno place with a yoshi or ideally teka box, they can reflash your standard ECU instead- much cheaper, and not much less good by all accounts. .
Got the best of both worlds, got the tuneboy software.
biggest thing I don't like about the SpeedTriple was the lack of control of the ecu, and having to pay a man to shove something on which I couldn't see anyway.
all changed now, total freedom on the ecu for everything.
Never thought I'd ever be tuning a bike with a laptop. but hey, done it several times already (each one better than the last, still learning) one cool bit of kit.
Cheers Mark.
Old 04-02-06, 12:06 AM   #9
Peter Henry
Well interesting debate going on here. I have noticed that stateside the guys swear by the PC. I have read with great interest also on several Ducati forums that many, as opposed to opting for the upgraded ECU from Ducati,( when for example changing exhaust systems) go for the Power Commander.
The beauty to me of the PC is that you can adjust the fuel/air mixture to optimum condtions throughout the firing range and works with your bog standard ECU. Additionally you can download a wide range of maps in order to find one that works best with your non standard fittings. A great bonus is that you can simply unplug it and fit it to any other bike you might buy in the future.
You can get pretty close to perfect setting by adjusting the PC yourself but yes if possible for the finite adjustments then a dynorun or similar would be advantageous.
For me the difference in the price of a Ducati upgrade chip(which does not always work as you would hope) is worth stumping up for the PC due to the greater flexibility.
I will definitely be buying one in a couple of months to set my bike up when the new zorst is fitted.
Old 04-02-06, 01:12 AM   #10
Jelster
I had my GSXR remapped and it was brilliant, and I shall be doing the same for the SV too. PC is great if you want to change the mapping regularly or maybe for a bike whose fuel system isn't particularly good.
The K4 & K5 machines (not sure about K3's) have excellent mapping in the first place, making the throttle very smooth - so I'm told. In which case there is nothing to "improve" on, just to tune, so I think the the PC3 is probably a bit overkill....
