Wotcha,
Just fitted one of these to my K3. Rather than pay the £20-25 for the kit I went to the scotoiler web site and ordered the components I'd need. http://www.scottoiler.com/pc/viewCat...?idCategory=10 Worked out about £10! You don't get the fitting instructions, obviously, but it's not difficult to work out. Just thought I'd share this bit of knowledge in case there are any others out there as tight as me! ![]() P.
http://ridingalongwayslowly.blogspot.co.uk/ 3x Honda C110 - phut-phut-phut KTM Duke 690 - brum-braaaaaaa!!!!! BSA C25 - brum-braa-braa RD350LC Ring-ding-phut-clatter-££££££ |
'counts down'
Cool info
Ringding, I'm interested in doing this conversion too. Could you tell me exactly which of the parts you ordered (the site shows quite a few parts)? I have a K5 SVS with Scottoiler fitted by dealer at new. It only oils the outer plates at the moment, so a dual injector sounds great!
Jon. |
#5 | |
#6 | |
Mr Squid will undoubtedly explain this far more elequently than I.
As far as I know, there are two reasons why you oil your chain - firstly to stop the outer surfaces getting rusty; and secondly to lubricate the contact with the sprockets. On the second of these points, this really doesn't take much oil, and I don't see how the dual injector really helps this. Perhaps if you're riding in exceptionally filthy conditions and need the extra flow of oil to wash the chain? If anything, by fitting this, you'll just use more oil, as well as incur the expense of buying it in the first place? ![]()
SV650 K3 - Gone. Now a member of the SV650.org Kawasaki brigade! |
I think the idea behind the dual injector is to keep the O-rings lubricated evenly
#9 |
I've always been told that the purpose of lubing your chain is to keep the o-rings lubricated and to lube the contact with the sprocket. (Not the same thing).
With the normal Scott Oiler only the outer O-rings were getting lubed. I had the same problem on my Triumph Trophy. In fact it hardly worked it's way onto the chain rollers either. Fitting the dual injector won't use more oil AFAIK as the drip rate is set at the reservoir. If you have two outlets at the chain end I think you're getting half a drip at each. It just spreads the delivery of the lube. I'm prepared to be proved wrong though! ![]() P.
#10 | |
http://www.scottoiler.com/UserFiles/...nstruction.pdf |
Injector flow | wojto | Bikes - Talk & Issues | 0 | 26-01-08 09:05 AM |
fuel injector size? | wildwestsydney | SV Talk, Tuning & Tweaking | 1 | 14-02-07 11:07 AM |
Mk7 Scottoiler and dual injector | Dodgy | For Sale - SV's and SV related items | 5 | 02-11-06 06:15 PM |
Finally ordered a scot oiler | MavUK | SV Talk, Tuning & Tweaking | 15 | 22-07-05 08:50 AM |
Scottoiler Injector positioning.... | Nekkid | Bikes - Talk & Issues | 15 | 22-03-05 08:20 PM |
