Exhausts Post your own reviews, opinions and experiences on this subject.
Old 06-02-06, 03:51 PM   #1
KayDee
Default Slip on or full system?
Is there any benifit to going for a full system over just a can? JHS racing said they could make a full system using m4 pipework and a leo vince road legal can (with removable baffle).
Old 06-02-06, 03:52 PM   #2
thor
Performance wise, not a lot, but the race systems are much lighter.
Old 09-02-06, 05:32 AM   #3
a1a
Unless you have increased the compression ratio, done valve work and replaced the cams. A full system is a waste of money in my opinion on the stock SV650. The differance between a full system and a Slip-on End Can with the stock SV650 is approx. 2 Horse Power at the top-end of the Rev range. Hardly cost effective, if you ask me.
It does keep you from cutting into your stock exhaust system though.
Cheers!
Old 09-02-06, 11:19 AM   #4
thor
I got a hindle full system for about £400. It's certainly a lot lighter than stock, so helps the handling when wobbling round tesco's carparks. Obviously you can get a slip on can for a lot less, but I like it.
Old 09-02-06, 04:55 PM   #5
a1a
I didn't mean to demean anyone who puts a full system on there stock SV my friend. I was just trying to state a point from a cost effective to HP gain point of view. Yes, you are right in that a full Titanium aftermarket exhaust system would be a weight saver.
If you do frequent track days and want the most from a stock SV650. That would be a different case scenario and one would consider a full Ti system for the weight advantage alone.
Cheers!
Old 09-02-06, 05:15 PM   #6
thor
Don't worry, I'm not offended! I just wanted to say that some full systems are a lot cheaper than others.
The hindle system is alu BTW.
Old 10-02-06, 05:45 AM   #7
a1a
I think the lightest system would probably be a full titanium exhaust with a carbon fiber End Can. But, they are pricey.
Did you say you have a full aluminum exhaust with the aluminum End Can made by Hindle? I thought most full exhaust systems were either titanium or stainless steel with choice of End Can?
Cheers!
Old 10-02-06, 09:21 AM   #8
thor
The can is stainless, but the pipes are certainly alu. Really, they weigh nothing!
http://www.hindle.com/road/html/suzuki.html
Akrapovic slip on vs. Laser exhaust system imaleon Bikes - Talk & Issues 11 13-08-08 11:46 AM
Akrapovic full system or yoshi full system ? ? ? hall13uk Exhausts 40 15-08-07 11:44 PM
full exaust vs slip on kcowgergmm SV Talk, Tuning & Tweaking 0 31-01-07 01:05 AM
Slip-On OR Full System? MitchC SV Talk, Tuning & Tweaking 27 29-01-05 09:28 PM
full system Rider99XX SV Talk, Tuning & Tweaking 8 06-01-70 08:34 AM
