Old 08-02-06, 08:15 PM   #1
sv650s_guy
Default front end
how hard is it to fit a gsxr100 front end on a k4 650
Old 08-02-06, 10:50 PM   #2
jhsracing
Default front end swap
It will fall straight in but you do need it all the complete front end, what do you entend to do about the speedo if you are using it on the road?
jh
www.jhsracing.co.uk
Old 09-02-06, 01:02 PM   #3
There's a guy on SV Rider that makes a simple hall-effect magnet pickup kit for the K3> bikes, quite neat and tidy. Better'n the countershaft pickup anyway.
Old 09-02-06, 07:45 PM   #4
sv650s_guy
what do u mean why will it affect speedo?
Old 09-02-06, 07:51 PM   #5
Carsick
The speedo on the SV is run off the front wheel. The GSXR speedo is run off the sprocket. If you want to know how fast you're going you will have to sort out another speedo drive.
Old 09-02-06, 08:01 PM   #6
sv650s_guy
didnt even know i had a speedo
how easy is that to do?
Old 09-02-06, 08:05 PM   #7
Carsick
See here
Old 09-02-06, 08:24 PM   #8
Bit of a cheek from SVRS there, it's a good kit but the prices are very high- the original kit offered through SV Rider (not by them) was around the $40 mark.
Old 10-02-06, 09:34 AM   #9
xj/frosty
yep it fits right on in --SUUURE --
Dont get me wrong compared to a lot of other front end swapps its a doddle but it aint a simple bolt on.
If you have yaself a thou front end start out by fitting up the triple clamps -I'm pretty sure the steering stops wont line up so youll have to figure out some new ones.--I drilled the lower clamp and used cap screws to act as stops--if you don't then a tank slapper will get pretty painfull.
I'm using TL thou handlebars because theyre higher than the gixxer bars and clear the fairing.
If it was me Id strip the forks out and get em rebuilt -- I went down to 095 springs and 15 weight oil.
Old 10-02-06, 07:57 PM   #10
sv650s_guy
how much would you guys at jhs charge for this? and how much is it for a titanium leovance system for a k4?
K3 front brake lever, Front indicator (RH), Front Mirror(RH), Bar End (RH) leegriffiths128 Stuff Wanted 0 23-07-08 09:11 PM
Front Discs (pair) for sv650 '99 curvy + Front wheel mikeSV Stuff Wanted 1 28-05-08 04:21 PM
Front Discs, For those with GSXR Front Ends on thier SV's Ter For Sale - SV's and SV related items 2 14-03-07 12:56 PM
SV650s 2000 model, yellow. I need front central and front right fairing. OdySV Stuff Wanted 0 25-02-07 04:47 PM
K3 radiator(any condition), front header pipe, FRONT END!!!! buttmunch Stuff Wanted 1 10-04-06 10:09 PM
