Old 09-02-06, 01:13 PM   #1
triumph5ta
Default Clutch thingy for a curvy, 1999...
or "screw assembly, clutch release" according to the parts fiche.
Its the gadget that turns the "pull" of the clutch cable into "push" on the clutch rod. I took mine off to clean it and a load of little ball bearings fell out... I put as many as I could back in and it does still work but is a bit "grabby". Brand new is £31 from Suzuki.... if anyone has a good one out there?.....
Adam.
Old 09-02-06, 10:34 PM   #2
dirtydog
Knob faced knobster
dirtydog's Avatar
I think i may well have one laying around. I'll check over the weekend.
2011 Speed Triple 1050
Old 10-02-06, 12:53 PM   #3
triumph5ta
Nice one, most grateful,
Adam.
Old 10-02-06, 09:35 PM   #4
Well Oiled
Default Re: Clutch thingy for a curvy, 1999...
Adam.
Can't you just get some ball bearings? easy enough to take it apart, grease it up and reassemble with new ones.
Old 10-02-06, 10:42 PM   #5
petevtwin650
Easy enough if you have the fingers of a 5 year old maybe.
Luckily my partner has.
Should be a warning on the flipping outer casing.
Old 13-02-06, 09:55 AM   #6
triumph5ta
Im not sure how they fit back in and I dont think they are supposed to fall out when you remove the release, therefore I think its worn out. Im not sure of size of the ball bearings and how many there should be , I think some were missing before I took it off... if DirtyDog doesnt have a spare I will have to get a new one.
Adam.
Old 13-02-06, 11:19 AM   #7
Mike1234
If they are the same as the fuel injected bike (can't see why not) I have a couple kicking around somewhere.
Old 13-02-06, 05:44 PM   #8
dirtydog
Knob faced knobster
dirtydog's Avatar
Right i found it, unfortunately it had all come apart and the bearings have gone AWOL
sorry
over to you mike
Old 14-02-06, 01:12 PM   #9
triumph5ta
Hi Mike, if you have a complete one can I buy it from you?
Adam
Old 16-02-06, 09:47 AM   #10
triumph5ta
Default Clutch thing for a 1999 curvy - SORTED, thanks Mike.
Got one from the excellent Mike, many thanks for all who offered help.
Adam.
Curvy Naked 1999 clutch cable Stevetmanchester Stuff Wanted 4 21-05-09 03:39 PM
Curvy single seat thingy simonthepost For Sale - SV's and SV related items 8 29-09-08 07:18 PM
Blue headlight protectors for curvy SV and a clip thingy!! POGS69 Stuff Wanted 2 31-01-08 10:40 PM
Various bit for 1999-2000 Curvy Gazz Stuff Wanted 2 22-05-06 02:57 PM
Clutch Thingy Barney SV Talk, Tuning & Tweaking 14 17-04-06 04:33 PM
