Old 10-02-06, 05:30 PM   #1
thepyrofish
Default Taking the battery out
My (new) bike which passed an MOT on Tuesday needs a new battery!
I have to charge the old knackered one to make it start so I can ride to the garage, though, and I don't know how to get at it. Is this an easy thing to do?
Cheers.
Old 10-02-06, 05:33 PM   #2
Freeloader
There are four allen key bolts which need removing to take your main seat off your bike. 1 each side holds a panel onto the side of the bike which when removed expose 2 allen key bolts clearly securing the seat.
Slide the seat off and you will find the battery underneath a fusebox there.
Old 10-02-06, 05:36 PM   #3
big twin grin
Very easy to do mate. Take away all of the usual bits around it ie seat etc. make sure you disconnect then earth first then the positive and lift it out. Easy!
Old 10-02-06, 05:48 PM   #4
thepyrofish
Thanks for the info, I've found it will put it on charge overnight.
Optimate battery charger drains the battery flymo Bikes - Talk & Issues 10 10-06-09 10:41 AM
What you taking?????? Drew Carey 2008 Annual Rideout 70 01-07-08 07:11 PM
Taking the law into your own hands... philbut Idle Banter 31 26-09-07 10:20 AM
What you taking, or how to buy friends timwilky 2007 Annual Rideout 30 27-06-07 11:50 PM
Battery/Starting problem - new battery hasnt fixed it! Aaron SV Talk, Tuning & Tweaking 13 24-01-05 05:21 PM
