Old 18-02-06, 09:10 PM   #1
seedy100
Default Heated Grips - Killing the battery?
Ive been using heated grips through the winter
35 miles each way two or three times a week.
Put the battery on a optimate probably twice a week.
Today I did about 200 miles
When trying to restart after a fuel stop I got a typical flat battery response from the starter.
With the grips off there was just enough to start up.
finished the journey without the grips and put the battery on charge when I got home. (Its a 9 month old battery)
The question is - would this be normal or am i looking at a charging problem?
Any thoughts
Old 18-02-06, 11:18 PM   #2
RandyO
there is plenty of juice from a properly operating electrical system to power heated grips on the SV.
sounds like your RR might only be working intermittently and not charging your battery
Old 19-02-06, 05:41 PM   #3
seedy100
Thanks Randy
Ebay it is then!
Old 19-02-06, 05:55 PM   #4
Still, it's a very good idea to have the grips wired into an ignition-switched live if you've not already. Take your example here= if you stop the bike and go in for petrol, and they're not ignition switches, they're constantly drawing power. Not a huge amount, but it could be enough.
I went a wee bit further when I did my epic rewire a few months ago, and put my relay for the grips into the headlight circuit. Now, my heated grips are on and off with the lights. If I'm ever dubious about the state of the battery, I can kill the 2 big, disposable power drains- the grips and the lights- with a single flick of a switch. Quite handy when starting from cold etc. Not brain surgery obviously, but it's kind of nice to have.
Old 20-02-06, 12:34 AM   #5
seedy100
Northwind;
The grips are wired in to the ignition, using the spare way on the fuse box.
(courtesy of a post on here - thanks)
I do like the idea of being able to turn the lights off for cold starts though.
I'll fit a switch inside the fairing next time it comes off.
Cheers.
Old 20-02-06, 12:44 AM   #6
hall13uk
can you turn you lights off then speedy
Heated grips Daywalker Bikes - Talk & Issues 3 17-02-09 01:08 PM
heated grips zsv650 Bikes - Talk & Issues 6 08-12-08 11:48 AM
Heated Grips? smidge26 Riding Gear 41 09-11-08 01:06 PM
getting heated grips off -more help please!! jenni SV Talk, Tuning & Tweaking 21 07-12-06 05:53 PM
Heated grips jimbobule Idle Banter 3 09-01-70 09:04 AM
