Old 20-02-06, 10:59 PM   #1
DavieSV
DavieSV's Avatar
Default same old gear lever out!
I have trouble finding time time to wash my bike at home, so wash it in my lunch break at work.
While cleaning the foot pegs noticed the gear changed pivot has come loose
it was only in by a couple of threads. I have read about this on here before.
I have fixed the problem for now, should I put a complaint in to Suzuki, as it could end up being a fatal flaw in the bike, and if so where to, or is it just one of those things to keep an eye on?
DavieSV is offline   Reply With Quote
Old 19-03-06, 09:12 PM   #2
zunkus
Are you talking about the gear link from the foot pedal? In case put some tread-lock in its tread.
Old 19-03-06, 10:18 PM   #3
Carsick
just keep an eye on it. It came off for me at about 4k but never once even came loose after I'd tightened it properly.
Old 20-03-06, 01:05 AM   #4
Funny, I was just adjusting mine today and it was practically seized. There's a middle ground there somewhere
Old 20-03-06, 09:55 AM   #5
Ceri JC
Ring up Suzuki, the lying ****ers will tell you "first we've heard of that, Sir". In spite of the fact that about 1/3 of K4s suffer this problem.
Old 21-03-06, 04:14 PM   #6
tomjones2
Mine was falling off but setting it to the correct toruqe in the manual seems to have kept it on.
Old 22-03-06, 08:35 PM   #7
DavieSV
DavieSV's Avatar
I noticed when screwing it back in (with thread lok) the peg screws in, the lever then slids on followed by a washer & then the cir-clip.
There needs to be a washer between the lever & the peg, therefore the friction would be reduced & less likely to unscrew.
Have not had time to do this yet, if it happens again I may machine a bit of the back of the lever & fit a washer
but untill that happens, I will just keep an eye on it
& anyway the salt will have corroded the aluminium by then and seezed the peg in
Gear Selection Lever and Clutch Lever for K3 SV650S xXBADGERXx Stuff Wanted 7 17-01-09 02:04 PM
How to straighten a bent gear lever? (heat it up first? or what?), ---possible fix or recipe for snapped of gear lever :-) martin_SV SV Talk, Tuning & Tweaking 10 30-07-08 08:40 PM
K5 Pointy 650S right hand wing mirror, gear lever and clutch lever. Bayside GTR Stuff Wanted 0 29-10-07 11:24 PM
2 left indicators + clutch lever + gear lever for pointy k6 enduroman Stuff Wanted 3 06-09-07 09:26 PM
Gear lever as rear brake lever? plowsie SV Talk, Tuning & Tweaking 2 29-05-07 05:23 PM
