Old 23-02-06, 09:48 PM   #1
timwilky
timwilky's Avatar
Default calling all window boffins
Why cannot I create a diretory with the name sys
if I attempt to create it
mkdir sys
I get The system cannot find the file specified.
I discovered this trying to install visual studio and the installation fails attempting to create C:\Program Files\Microsoft Visual Studio 8\VC\crt\src\sys
At first I thought it was protection or too many sub directories etc. but no it simply does not like a directory to be named sys
BTW XP Professional SP2 patched upto date
Googled and googled but cant find anything obvious
Not Grumpy, opinionated.
Old 23-02-06, 10:08 PM   #2
amarko5
Erm tim right click and make new folder then name sys
mine lets me service pack 2 win xp pro
Old 23-02-06, 10:22 PM   #3
timwilky
timwilky's Avatar
no that don't work
First thing I tried was to use the file explorer, I get "cannot rename new folder: cannot find the specified file"
Old 23-02-06, 10:30 PM   #4
TSM
The Sick Man
TSM's Avatar
Umm, there should be no reason that it does not work. SYS is not a reserved word in windows. What i mean by that is you cannot call a folder LPT1 or COM1 etc.. because they are reserved. I tried what you have and its fine on my comp.
Old 23-02-06, 10:33 PM   #5
amarko5
the only thing i can think of Tim possibly you already have a folder named sys maybe hidden from view try using the folder options to make all folders and files visible.
i have tried it on 3 machines now all xp in various guises and not one complains at all
Old 23-02-06, 11:36 PM   #6
timwilky
timwilky's Avatar
Can do it no problem when I am in safe mode but not when windows starts normally. I have removed my anti virus etc still cannot find cause of this problem
Old 24-02-06, 12:09 AM   #7
amarko5
A perplexing little problem their Tim are you the administrator on that machine ?
is there a possibility there is still something of the antivirus or even windows own firewall that is perhaps not allowing the creation of the folder.
and if you create it in safe mode will it not still be there when you start widows normally ?
Old 24-02-06, 12:21 AM   #8
setanta
Why do you "need" to call it sys if it dosnt work
Old 24-02-06, 07:18 AM   #9
mysteryjimbo
I should check the permissions on the parent folder and make sure they arent restricted in anyway.
If you'de in XP pro you can turn off "use simple folder permissions" in folder options.
Old 24-02-06, 12:30 PM   #10
Lou M
And there was me thinking from the subject that you had a problem with your double glazing.
Car audio boffins please _Stretchie_ Idle Banter 21 18-11-08 05:48 PM
Any chemistry boffins out there? pben47 Idle Banter 9 13-10-08 01:52 PM
Any gym boffins in here Shellywoozle Idle Banter 15 29-08-08 10:46 PM
calling all geeks(in the nicest name calling way) jim@55 Idle Banter 11 25-06-07 08:55 AM
Should I be sat at my desk by the window...? Fizzy Fish Idle Banter 11 05-02-07 01:36 PM
